在缺水的地中海农业生态系统中可持续生产大麦
水资源稀缺是干旱和半干旱地区农业活动的主要制约因素之一。尽管近几十年来取得了巨大的技术发展,但农民仍需要适应其培训、管理限制和经济能力的方法和工具。为了应对这些挑战,地中海农业生态系统(SUPROMED)项目在水资源有限的环境中的可持续生产在一个在线平台上结合了一套模型和方法,以更有效地管理水、能源和肥料。在卡斯蒂利亚-拉曼恰地区(西班牙)进行了一项为期两年的试验(2020-2021年),以证明 SUPROMED 作为一种农场管理支持工具对于大麦作物的有效性。通过分析一组生产、经济和环境因素,确定将农田灌溉用水经济优化模型(MOPECO 模型)灌溉调度以及集成在 SUPROMED 平台中的其他方法和工具传递给农民的影响。关键绩效指标(KPI)。选择KPI是为了向农民展示有效利用生产要素如何提高农场的盈利能力,从而减少农业对环境的影响。2020年,SUPROMED提出的管理计划实现了与传统管理相同的产量,用水量减少了32%,达到了13%和66%。毛利率和总经济灌溉用水生产率分别提高。2021年,一名受过使用 SUPROMED 平台工具和方法培训的农民实施的管理显示,所分析的大多数KPI都有所改善,取得了与SUPROMED在2020年获得的结果相似的结果。结果很有希望,表明SUPROMED 中提出的工具和模型可以很容易地被农民使用,并且可以提高地中海农业生态系统的经济和环境可持续性。生产部门有效推广和使用这些方法需要公共行政部门以及当地研究人员和技术人员的参与。
“MOPECO灌溉调度”工具模拟的2020年可用水演变
Sustainable Production of Barley in a Water-Scarce Mediterranean Agroecosystem
Abstract
Scarcity of water resources is one of the main constraints on agricultural activity in arid and semi-arid areas. Despite the great technological development over recent decades, farmers are demanding methodologies and tools adapted to their training, management restrictions, and economic capacity. To tackle these challenges, the sustainable production in water-limited environments of Mediterranean agroecosystems (SUPROMED) project combines, in an online platform, a set of models and methodologies for more efficient management of water, energy, and fertilizers. A two-year trial (2020–2021) was conducted in the Castilla-La Mancha region (Spain) to demonstrate, for a barley crop, the effectiveness of SUPROMED as a farm management support tool. The impact of transferring the model for the economic optimization of irrigation water use at farm level (MOPECO model) irrigation scheduling among other methods and tools, integrated in the SUPROMED platform, to farmers was determined by analyzing a set of productive, economic, and environmental key performance indicators (KPIs). The KPIs were selected to show farmers how the efficient use of productive factors could improve the profitability of their farms, thus reducing the impact of agriculture on the environment. In 2020, the management plan proposed by SUPROMED achieved the same yield as traditional management using 32% less water and resulting in a 13% and 66% improvement in gross margin and gross economic irrigation water productivity, respectively. In 2021, the management implemented by a farmer trained in the use of the tools and methodologies in the SUPROMED platform showed improvements in most of the KPIs analyzed, achieving similar results to those obtained by SUPROMED during 2020. The results are promising, indicating that the tools and models proposed in SUPROMED can be easily used by farmers and can improve the economic and environmental sustainability of Mediterranean agroecosystems. The involvement of public administrations, together with local researchers and technicians, is required for the effective promotion and use of these methodologies by the productive sector.
Pessl植物生理生态监测系统的全套监测系统和在线平台FieldClimate适用于所有气候区,可用于各种行业和各种用途——从农业到研究、水文、气象、洪水警报等。iMetos植物生理生态监测系统已经成为一个全球品牌,使用持续时间更长,性能更好,是通用的天气监测设备,具有早期识别和警报功能(有SMS手机提醒功能);可以用来计划、控制和管理复杂的独立气象过程。该监测系统专为不同气候区域的多种任务而设计。其可以安装多达600个传感器,如土壤和空气湿度、温度、降雨、风速、风向、叶片 湿度、总体辐射等传感器。
Pessl植物生理生态监测系统的数据采集工作站可以将这些数据无线传输到安全的互联网数据库上。该数据库是优秀的数据存储和处理平台。用户获得登录密码后,可以从世界任何地方的互联网终端登录并获得这些数据、报告和图表。测量的信息来源于传感器所在的位置。使用者可以从网站上一个区域可输入或修改阈值和电话号码。操作无需专门软件。
Pessl植物生理生态监测系统仅需要有效的GPRS协议用于数据传输,在站点所在处也需要网络的充分覆盖。该系统是一组多功能、模块化配置的系统,运行完全免维护。该工作站采用太阳能充电电池。工作站可以连接多种传感器。即插即用模式便于工作站扩展传感器数目。
相关阅读
