当前位置 > 首页 > 技术文章 > 基于NB-IoT和能量收集技术的葡萄霜霉病预警系统
浏览次数:351 发布日期:2022-9-20  来源:本站 仅供参考,谢绝转载,否则责任自负
Pessl植物生理生态监测系统的全套监测系统和在线平台FieldClimate适用于所有气候区,可用于各种行业和各种用途——从农业到研究、水文、气象、洪水警报等。iMetos植物生理生态监测系统已经成为一个全球品牌,使用持续时间更长,性能更好,是通用的天气监测设备,具有早期识别和警报功能(有SMS手机提醒功能);可以用来计划、控制和管理复杂的独立气象过程。该监测系统专为不同气候区域的多种任务而设计。其可以安装多达600个传感器,如土壤和空气湿度、温度、降雨、风速、风向、叶片 湿度、总体辐射等传感器。
摘要:影响葡萄生产的一个主要问题是真菌病原体的侵扰,其中葡萄疟原虫是最严重的一种,引起葡萄霜霉病。这可能会对葡萄园造成重大损害,从而导致经济损失。预测疾病爆发的方法依赖于气象参数的监测。随着物联网 (IoT) 技术的最新发展,可以有效地大规模收集原位数据。在本文中,提出了一种基于窄带物联网(NB-IoT)和能量收集的葡萄霜霉病预警系统实施新模型。霜霉病预警系统的模型已经从早期的基于温度(后来基于湿度)的模型发展为最新的机制模型,包括降雨/叶片湿度和每小时监测。我们添加了“有利的夜间条件”和“风速”等参数作为孢子囊传播的关键。该模型与商业 iMetos® 警告系统和三个特定葡萄园位置的最新机械模型的比较表明警报之间的高度相关性。
Grapevine Downy Mildew Warning System Based on NB-IoT and Energy Harvesting Technology
One major problem that affecting grape production is that of infestations by fungal pathogens, among which Plasmopara viticola is one of the worst, causing grapevine downy mildew. This can cause substantial damage to a vineyard, which leads to economic losses. Methods of predicting disease outbreak rely on the monitoring of meteorological parameters. With the recent development of Internet of Things (IoT) technologies, in situ data can be efficiently collected on a large scale. In this paper, a new model with early warning system implementation for grapevine downy mildew based on Narrow Band IoT (NB-IoT) and energy harvesting is presented. Models of downy mildew warning systems have evolved from the early temperature-based (and later, humidity-based) models to the latest mechanistic models which include rainfall/leaf wetness and hourly monitoring. We added parameters such as ’favorable night condition’ and ’wind speed’ as critical for sporangia spreading. The comparison of the model with the commercial iMetos® warning system and the latest mechanistic model for three specific vineyard locations indicates a high correlation between alarms.
相关阅读
iMETOS植物生理生态监测系统
CropVIEW植物物候监测系统
Pessl植物生理生态监测系统:雪和寒冷是如何影响小麦生产
Pessl植物生理生态系统:不同生长习性大豆品种产量与基因型x环境互作
Pessl植物生理生态系统:同化光照下番茄茎直径模型的改进
Pessl植物生理生态系统:早疫病预报系统对检测西班牙西北部马铃薯作物首发症状的适用性
Pessl植物生理生态系统:在非传统葡萄种植条件下使用数学模型评估砧木类型对葡萄藤产量参数的影响
Pessl植物生理生态系统:热带条件下多年生黑麦草水分胁迫阈值及Ks系数评估
Pessl植物生理生态系统:iMETOS®sm病害预测系统预测不同农业生态区的链格孢感染情况
Pessl植物生理生态系统:越南山区预防山洪暴发的强大预警系统
来源:北京博普特科技有限公司
联系电话:010-82794912
E-mail:1206080536@qq.com
