热点
最古老的品种在冷藏前ChlSPAD和ChlDX的值最高。
现代品种表现出较好的再生能力。
SPAD值是番茄再生期低温状态的良好指标
摘要
对过去80年来在南欧广泛种植的六种加工番茄幼苗进行了比较,以评估其对低温的生理反应。低温胁迫24小时 h(1 摄氏度(昼夜)。PEARSON是最古老的品种,使用DUALEX(ChlDX)和 = 23.11)和SPAD(ChlSPAD = 氮平衡指数(NBIDX.27) = 29.62)在低温胁迫前用DUALEX测量。品种E6203对低温最不敏感,在再生期最大光系统II(PSII)效率(Fv/Fm2)最高,恢复和可见再次生长评分(VS3)为0.64 = 4.0)最大。就最大PSII效率而言,除了最敏感的C33外,品种间的耐寒性几乎没有差异。另一方面,现代品种再次生长能力更强。在低温胁迫之前(SPAD和DUALEX)和之后(最大PSII效率、SPAD和电解质泄漏)的不同参数之间都发现了很强的相关性。再生期SPAD值是番茄再生期低温状态的良好指标。基于微卫星标记的遗传相似性分析根据发布年份明确区分了现代品种和老品种。这一信息有助于培育适合早期移植的新品种,因为此时可能会发生冷害。
Physiological responses to chilling in cultivars of processing tomato released and cultivated over the pat decades in Southern Europe
Highlights
The oldest cultivarreported the highest values of ChlSPAD and ChlDX before chilling.
Modern cultivarsshowed better regrowth.
SPAD values are a good indicator of tomato chilling status at regrowth period
Abstract
Six processing tomato seedlings, representative of cultivars widely cultivated over the last 80 years in Southern Europe, were compared to assess the physiological responses to chilling. Low temperature stress was applied for 24 h (1 °C, day and night). PEARSON, the oldest cultivar, reported the highest values of chlorophyll content both using DUALEX (ChlDX = 23.11) and SPAD (ChlSPAD = 35.27) and nitrogen balance index (NBIDX = 29.62) measured with DUALEX, before chilling stress. The cultivar E6203 was the least sensitive to chilling with the highest value of maximal photosystem II (PSII) efficiency (Fv/Fm2 = 0.64) at recovery and visual regrowth score (VS3 = 4.0) at regrowth period. As regards chilling tolerance in terms of maximal PSII efficiency, few differences were observed among the cultivars, apart from C33, that was the most sensitive. On the other hand, a better regrowth was recorded in the modern ones. Strong correlations were found between the different parameters investigated both before (SPAD and DUALEX) and after the chilling stress (maximal PSII efficiency, SPAD and electrolyte leakage). SPAD values at regrowth were shown to be a good indicator of tomato chilling status at regrowth period. Analysis of genetic similarity based on microsatellite markers clearly discriminated modern and old varieties according to the year of release. This information could be useful in breeding programs for new cultivars suitable for early transplant, when chilling injury can happen.
Keywords
Processing tomato seedlings
Chilling stress
Optical measurements
Electrolyte leakage
Regrowth
Phenotyping
Dualex是一款源自于法国国家科学院 (CNRS)及巴黎第十一大学技术,由奥地利PESSL公司生产(原法国Force-A公司)开发的新型多功能叶片测量仪。它可同时准确测量叶片的叶绿素含量、叶片表层的类黄酮和花青素含量,适用于植物生理学和农学(如水稻叶绿素浓度,玉米氮素状况,葡萄藤等)相关研究。其测量对象可以是单子叶植物,双子叶植物或多年生植物。这款设备简单易用,可进a行实时和非破坏性测量。由于不需要校准标定和事先的样品制备,测量工作可在实验室或现场完成。此外,该设备在各种温度的和环境光照条件下均可正常使用。系统采用专利设计,光学传感器可进行简单、快速、无损测量叶片中的叶绿素、多酚以及花青素。
相关阅读
Dualex 便携式智能气象-叶绿素-花青素-黄酮醇测量仪
PESSL便携式便携式植物多酚-叶绿素仪原理
Dualex植物多酚-叶绿素仪:腐殖酸通过铁依赖和非铁依赖的协同机制缓解禾本科植物的铁失绿症
Dualex植物多酚-叶绿素仪:硝化抑制剂和/或间作效应下玉米(和小麦灌溉种植系统中的硝酸盐淋失
Dualex植物多酚-叶绿素仪:与保持绿色表达相关的叶片和冠层性状与对水分胁迫具有不同耐性的小麦基因型的产量构成密切相关
Dualex植物多酚-叶绿素仪:基于地面和智能传感器的冬小麦营养营养仪
Dualex植物多酚-叶绿素仪:增加角质层蜡沉积不会改变残余叶片蒸腾作用
Dualex植物多酚-叶绿素仪--氮平衡指数:不同生物刺激剂对水培生菜的效果比较
Dualex植物多酚-叶绿素仪:固体消化物和葡萄园冬季修剪堆肥替代苗圃中微繁殖高丛蓝莓生长基质中的泥炭研究
Dualex植物多酚-叶绿素仪:不同灌溉制度下根际细菌和藻类对金盏草生理生化指标的影响
Dualex植物多酚-叶绿素仪:Sentinel-2A与近端传感器数据协同提取水稻不同生育期生化参数
Dualex植物多酚-叶绿素仪:三种便携式光学传感器在冬小麦氮素状况无损诊断中的应用
Dualex植物多酚-叶绿素仪:基于微碳技术(MCT®)的肥料对土壤和辣椒生长室和田间培养的生物刺激效应
Dualex植物多酚-叶绿素仪:根际细菌在减轻大豆干旱胁迫中的作用
Dualex植物多酚-叶绿素仪:不同辐射组分下水分亏缺对苹果幼苗生长的影响
Dualex植物多酚-叶绿素仪:不同的非生物光谱途径揭示了不同物种的病原体应激信号
Dualex植物多酚-叶绿素仪:用于在田间估算葡萄叶片氮状况的反射指数和手持设备的性能
Dualex植物多酚-叶绿素仪:短期采前补充UV-B可提高罗勒叶片贮藏期间的多酚含量和抗氧化能力
Dualex植物多酚-叶绿素仪:基于图像处理技术的5种红树林叶片形态特征及叶绿素相对含量的估测
Dualex植物多酚-叶绿素仪:利用叶片荧光传感器估算玉米各生育期植株氮浓度Dualex植物多酚-叶绿素仪:便携式叶绿素仪测量作物叶片叶绿素浓度的评估Dualex植物多酚-叶绿素仪:从高光谱图像和SIF反演估算辐射传输Vcmax来评估雨养和灌溉植物表型试验中的光合性能
Dualex植物多酚-叶绿素仪:单金属和双金属植物纳米颗粒对Mezquit生理状态的影响
Dualex植物多酚-叶绿素仪:LED照明剂量对tatsoi光合指标的影响
Dualex植物多酚-叶绿素仪:利用Dualex非破坏性测量确定不同甜樱桃园的覆盖下光有效性™
Dualex植物多酚-叶绿素仪:硅在渗透胁迫下介导两种不同番茄基因型差异耐逆反应中的调节作用
Dualex植物多酚-叶绿素仪:用非破坏性荧光传感器监测两个苹果品种对供水条件的生理生化反应
Dualex植物多酚-叶绿素仪:从Sentinel-2光谱带反演冠层叶绿素含量以估算冬小麦集约种植系统的氮素吸收
Dualex植物多酚-叶绿素仪:胚胎大小作为种子捕食耐受性性状:胚胎受损种子对植株再生的贡献
Dualex植物多酚-叶绿素仪:干旱和高温对4个冬小麦基因型光合特性的联合效应
