当前位置 > 首页 > 技术文章 > LI-6800“光合-荧光同步测量”部分文献列表
浏览次数:1609 发布日期:2020-11-23  来源:本站 仅供参考,谢绝转载,否则责任自负
来源:Google学术
Kitao M, Agathokleous E, Harayama H, et al. Constant ratio of Cc to Ci under various CO 2 concentrations and light intensities, and during progressive drought, in seedlings of Japanese white birch[J]. Photosynthesis Research, 2020: 1-11.
Jablonski A, Kruger E L, Townsend P A. Comparative responses of solar-induced fluorescence (SIF) and leaf photosynthetic parameters to short term atmospheric CO 2 enrichment[J]. AGUFM, 2017, 2017: B51H-1920.
Evans J R, Morgan P B, von Caemmerer S. Light quality affects chloroplast electron transport rates estimated from Chl fluorescence measurements[J]. Plant and Cell Physiology, 2017, 58(10): 1652-1660.
McClain A M, Sharkey T D. Building a better equation for electron transport estimated from Chl fluorescence: accounting for nonphotosynthetic light absorption[J]. New Phytologist, 2020, 225(2): 604-608.
Pratt R B, Castro V, Fickle J C, et al. Factors controlling drought resistance in grapevine (Vitis vinifera, chardonnay): application of a new micro CT method to assess functional embolism resistance[J]. American Journal of Botany, 2020, 107(4): 618-627.
Zhuang J, Wang Y, Chi Y, et al. Drought stress strengthens the link between chlorophyll fluorescence parameters and photosynthetic traits[J]. PeerJ, 2020, 8: e10046.
Urban L, Aarrouf J, Bidel L P R. Assessing the effects of water deficit on photosynthesis using parameters derived from measurements of leaf gas exchange and of chlorophyll a fluorescence[J]. Frontiers in plant science, 2017, 8: 2068.
Kang H X, Zhu X G, Yamori W, et al. Concurrent Increases in Leaf Temperature With Light Accelerate Photosynthetic Induction in Tropical Tree Seedlings[J]. Frontiers in plant science, 2020, 11: 1216.
Avenson T J, Saathoff A J. Sub-saturating multiphase flash irradiances to estimate maximum fluorescence yield[M]//Photosynthesis. Humana Press, New York, NY, 2018: 105-120.
Cheng D, Zhang Z, Zhou S, et al. Relationships between leaf physiognomy and sensitivity of photosynthetic processes to freezing for subtropical evergreen woody plants[J]. iForest-Biogeosciences and Forestry, 2019, 12(6): 551.
Guha A, Han J, Cummings C, et al. Differential ecophysiological responses and resilience to heat wave events in four co-occurring temperate tree species[J]. Environmental Research Letters, 2018, 13(6): 065008.
Slot M, Krause G H, Krause B, et al. Photosynthetic heat tolerance of shade and sun leaves of three tropical tree species[J]. Photosynthesis Research, 2019, 141(1): 119-130.
Lantz A T, Solomon C, Gog L, et al. Isoprene suppression by CO2 is not due to triose phosphate utilization (TPU) limitation[J]. Frontiers in Forests and Global Change, 2019, 2: 8.
Boaretto R M, Hippler F W R, Ferreira G A, et al. The possible role of extra magnesium and nitrogen supply to alleviate stress caused by high irradiation and temperature in lemon trees[J]. Plant and Soil, 2020: 1-14.
Salesse‐Smith C E, Sharwood R E, Busch F A, et al. Increased Rubisco content in maize mitigates chilling stress and speeds recovery[J]. Plant Biotechnology Journal, 2020, 18(6): 1409.
Zhang Q, Zhai J, Shao L, et al. Accumulation of anthocyanins: an adaptation strategy of Mikania micrantha to low temperature in winter[J]. Frontiers in Plant Science, 2019, 10: 1049.
Fgaier S, de Almeida Lopes M M, de Oliveira Silva E, et al. Xenon lamps used for fruit surface sterilization can increase the content of total flavonols in leaves of Lactuca sativa L. without any negative effect on net photosynthesis[J]. PloS one, 2019, 14(10): e0223787.
Tominaga J, Shimada H, Kawamitsu Y. Direct Measurement Solves Overestimation of Intercellular CO2 Concentration in Leaf Gas-Exchange Measurements[J]. Journal of Experimental Botany, 2018.
Carr N F, Boaretto R M, Mattos Jr D. Coffee seedlings growth under varied NO3−: NH4+ ratio: Consequences for nitrogen metabolism, amino acids profile, and regulation of plasma membrane H+-ATPase[J]. Plant Physiology and Biochemistry, 2020.
Liu Y, Qi Y, Chen X, et al. Phenolic compounds and antioxidant activity in red-and in green-fleshed kiwifruits[J]. Food Research International, 2019, 116: 291-301.
Wan J, Zhang P, Wang R, et al. Comparative physiological responses and transcriptome analysis reveal the roles of melatonin and serotonin in regulating growth and metabolism in Arabidopsis[J]. BMC plant biology, 2018, 18(1): 362.
Spielman-Sun E, Avellan A, Bland G D, et al. Nanoparticle surface charge influences translocation and leaf distribution in vascular plants with contrasting anatomy[J]. Environmental Science: Nano, 2019, 6(8): 2508-2519.
Ermakova M, Lopez-Calcagno P E, Raines C A, et al. Overexpression of the Rieske FeS protein of the Cytochrome b6f complex increases C4 photosynthesis[J]. bioRxiv, 2019: 574897.
Reyes T H, Esparza E, Crestani G, et al. Physiological responses of maca (Lepidium meyenii Walp.) plants to UV radiation in its high-altitude mountain ecosystem[J]. Scientific reports, 2020, 10(1): 1-13.
Chen X, Zhao P, Ouyang L, et al. Whole-plant water hydraulic integrity to predict drought-induced Eucalyptus urophylla mortality under drought stress[J]. Forest Ecology and Management, 2020, 468: 118179.
Suchoff D H, Perkins-Veazie P, Sederoff H W, et al. Grafting the indeterminate tomato cultivar Moneymaker onto Multifort rootstock improves cold tolerance[J]. HortScience, 2018, 53(11): 1610-1617.
Thais H R, Eliana E, Gaia C, et al. Physiological responses of maca (Lepidium meyenii Walp.) plants to UV radiation in its high-altitude mountain ecosystem[J]. Scientific Reports (Nature Publisher Group), 2020, 10(1).
Yang J. Diurnal and Seasonal Proximally Sensed Photochemical Reflectance Index (PRI) in a High-Stress Semi-Arid Mixed Conifer Forest[J]. 2019.
Mazis A, Choudhury S D, Morgan P B, et al. Application of high-throughput plant phenotyping for assessing biophysical traits and drought response in two oak species under controlled environment[J]. Forest Ecology and Management, 2020, 465: 118101.
来源:基因有限公司农业环境部
联系电话:010-66001566,66001653
E-mail:marketing@ecotek.com.cn
标签: LI-6800
