FMT150藻类培养与在线监测系统参考文献目录
浏览次数:4754 发布日期:2019-7-10
FMT150藻类培养与在线监测系统将生物反应器与监测仪器独特地结合在一起,用于淡水、海水藻类和蓝细菌(蓝藻)等的模块化精确光照培养与生理监测。
FMT150可以通过控制单元(包括电脑与预装软件,软件分为基本版与高级版)中用户自定义程序动态自动改变培养条件并实时在线监测培养条件与测量参数。光强、光质、温度和通入气体的组分与流速都可以精确调控。加装恒浊和恒化模块后还可以调控培养基的pH值和浊度。FMT150可连接多达7个蠕动泵进行不同恒化与pH条件培养。培养条件可以根据用户自定义方案动态变化,既可以进行恒定条件下的培养,也可以一定的周期自动变化。控制单元可同时控制多台FMT150进行同步实验,保证不同处理实验间的一致性。
仪器内置叶绿素荧光仪和光密度计等。培养藻类的生长状况由光密度计测定OD680和OD720实现实时监控,并可以通过OD值监测相对叶绿素浓度。叶绿素荧光仪实时监测Ft并可测定F0、Fm、Fm′和QY来反映培养藻类的光合生理状态。
参考文献:
1. Multiomics resolution of molecular events during a day in the life of Chlamydomonas. Strenkert D, et al. 2019, PNAS, 116 (6): 2374-2383
2. Chlorella vulgaris integrates photoperiod and chloroplast redox signals in response to growth at high light. Hollis L, et al. 2019, Planta, 249(4): 1189-1205
3. Growth kinetics and mathematical modeling of Synechocystis sp. PCC 6803 under flashing light. Straka L, et al. 2019, Biotechnology and bioengineering, 116(2): 469-474
4. CO2 Capture for Industries by Algae. Anguselvi V, et al. 2019, Algae, DOI: 10.5772/intechopen.73417
5. Glycolate from microalgae: an efficient carbon source for biotechnological applications. Taubert A, et al. 2019, Plant biotechnology journal, DOI: 10.1111/pbi.13078
6. Response of the thylakoid proteome of Synechocystis sp. PCC 6803 to photohinibitory intensities of orange-red light. Cordara A, et al. 2018, Plant physiology and biochemistry, 132: 524-534
7. Effect of culture density on biomass production and light utilization efficiency of Synechocystis sp. PCC 6803. Straka L, et al. 2018, Biotechnology and bioengineering, 115(2): 507-511
8. Effect of carbon limitation on photosynthetic electron transport in Nannochloropsis oculata. Zavřel T, et al. 2018, Journal of Photochemistry and Photobiology B: Biology, 181:31-43
9. Diel regulation of photosynthetic activity in the oceanic unicellular diazotrophic cyanobacterium Crocosphaera watsonii WH8501. Masuda T, et al. 2018, Environmental Microbiology, 20(2): 546–560
10. Analysis of the light intensity dependence of the growth of Synechocystis and of the light distribution in a photobioreactor energized by 635 nm light. Cordara A, et al. 2018, PeerJ, 6:e5256, DOI 10.7717/peerj.5256
11. Cultivation, characterization, and properties of Chlorella vulgaris microalgae with different lipid contents and effect on fast pyrolysis oil composition. Adamakis ID, et al. 2018, Environmental Science and Pollution Research International, 25(23):23018-23032
12. Dynamic response of Synechocystis sp. PCC 6803 to changes in light intensity. Straka L, et al. 2018, Algal Research, 32:210-220
13. Growth bottlenecks of microalga Dunaliella tertiolecta in response to an up-shift in light intensity. Binte Safie SR, et al. 2018, European Journal of Phycology, 53(4): 509-519
14. Advancement of the cultivation and upscaling of photoautotrophic suspension cultures using Chenopodium rubrum as a case study. Segečová A, et al. 2018, Plant Cell, Tissue and Organ Culture, 135(1): 37–51
15. Enhanced biomass production of Scenedesmus obliquus in a flat-panel photobioreactor, grown in photoautotrophic mode. Trivedi J, et al. 2018, Biofuels, DOI: 10.1080/17597269.2018.1448634
16. Comparison of ethanol tolerance between potential cyanobacterial production hosts. Kämäräinen J, et al. 2018, Journal of biotechnology, 283:140-145
17. Rerouting of metabolism into desired cellular products by nutrient stress: Fluxes reveal the selected pathways in cyanobacterial photosynthesis. Qian X, et al. 2018, ACS synthetic biology, 7(5): 1465-1476
18. Growth of algal biomass in laboratory and in large-scale algal photobioreactors in the temperate climate of western Germany. Schreiber C, et al. 2017, Bioresource Technology, 234:140-149.
19. Intracellular spectral recompositioning of light enhances algal photosynthetic efficiency. Fu W, et al. 2017, Science Advances, 3(9): e1603096
20. Carotenoid Production Process Using Green Microalgae of the Dunaliella Genus: Model-Based Analysis of Interspecies Variability. Fachet M, et al. 2017, Ind. Eng. Chem. Res., 56(45): 12888-12898
21. Light attenuation changes with photo-acclimation in a culture of Synechocystis sp. PCC 6803. Straka L, et al. 2017, Algal Research, DOI: 10.1016/j.algal.2016.11.024
22. Metabolic Flexibility Underpins Growth Capabilities of the Fastest Growing Alga. Treves H, et al. 2017, Current Biology, 27(16): 2559-2567
23. Quantitating active Photosystem II reaction center content from fluorescence induction transients. Murphy CD, et al. 2017, Limnology and Oceanography: Methods, 15(1): 54-69
24. Comparative evaluation of phototrophic microtiter plate cultivation against laboratory-scale photobioreactors. Morschett H, et al. 2017, Bioprocess and Biosystems Engineering, 40(5): 663-673
25. Impaired mitochondrial transcription termination disrupts the stromal redox poise in Chlamydomonas. Uhmeyer A, et al. 2017, Plant Physiology, 174(3): 1399-1419
26. Interactive effects of nitrogen and light on growth rates and RUBISCO content of small and large centric diatoms. Li G, et al. 2017, Photosynthesis Research, 131(1): 93-103
27. A method to decompose spectral changes in Synechocystis PCC 6803 during light-induced state transitions. Acuña AM, et al. 2016, Photosynthesis Research, 130 (1) : 1-13
28. Comparison of D1´‐and D1‐containing PS II reaction centre complexes under different environmental conditions in Synechocystis sp. PCC 6803. Crawford TS, et al. 2016, Plant, Cell & Environment, 39(8): 1715-1726
29. The source of inoculum drives bacterial community structure in Synechocystis sp. PCC6803-based photobioreactors. Zevin AS, et al. 2016, Algal Research, 13: 109-115
30. Flow cytometry enables dynamic tracking of algal stress response: A case study using carotenogenesis in Dunaliella salina, Fachet M, et al. 2016, Algal Research, 13: 227-234
31. The nitrogen costs of photosynthesis in a diatom under current and future pCO2, G Li, et al. 2015, New Phytologist, 205(2): 533-543
32. Synechococcus elongatus UTEX 2973, a fast growing cyanobacterial chassis for biosynthesis using light and CO2. J Yu, et al. 2015, Sci Rep. 5: 8132.
33. Sustained circadian rhythms in continuous light in Synechocystis sp. PCC6803 growing in a well-controlled photobioreactor. P van Alphen, et al. 2015, PLoS ONE 10(6): e0127715.
34. Effects of phosphate limitation on soluble microbial products and microbial community structure in semi‐continuous Synechocystis‐based photobioreactors. AS Zevin, et al. 2015, Biotechnology and Bioengineering, 112(9): 1761-1769
35. Cultivation of Nannochloropsis for eicosapentaenoic acid production in wastewaters of pulp and paper industry. A Polishchuk, et al. 2015, Bioresource Technology, 193: 469-476
36. Interactive effects of and light on growth rates and RUBISCO content of small and large centric diatoms. G Li, et al. 2015, Biogeosciences Discuss., 12: 16645-16672
37. The role of an electron pool in algal photosynthesis during sub-second light–dark cycling. C Vejrazka, et al. 2015, Algal Research, 12: 43-51
- A dynamic growth model of Dunaliella salina: Parameter identification and profile likelihood analysis, M Fachet, et al. 2014, Bioresource Technology, 173: 21-31
- Effects of light and circadian clock on growth and chlorophyll accumulation of Nannochloropsis gaditana, R Braun, et al. 2014, Journal of Phycology, 50(3): 515-525
- Ultradian metabolic rhythm in the diazotrophic cyanobacterium Cyanothece sp. ATCC 51142, J Červený, et al. 2013, PNAS, 110(32): 13210-13215
- Temperature-dependent growth rate and photosynthetic performance of Antarctic symbiotic alga Trebouxia sp. cultivated in a bioreactor, K Balarinová, et al. 2013, Czech polar reports, 3 (1): 19-27
- Rising CO2 Interacts with Growth Light and Growth Rate to Alter Photosystem II Photoinactivation of the Coastal Diatom Thalassiosira pseudonana, Gang Li, et al. 2013, PLOS ONE, 8(1)
- Photosystem II protein clearance and FtsH function in the diatom Thalassiosira pseudonana, DA Campbell, et al. 2013, Photosynthesis Research, 115(1): 43-54
- Photosynthetic efficiency and oxygen evolution of Chlamydomonas reinhardtii under continuous and flashing light, C Vejrazka, et al. 2013, Applied Microbiology and Biotechnology, 97(4): 1523-1532
- Natural variants of Photosystem II subunit D1 tune photochemical fitness to solar intensity, DJ Vinyard, et al. 2013, Journal of Biological Chemistry, 288: 5451-5462
- The mTERF protein MOC1 terminates mitochondrial DNA transcription in the unicellular green alga Chlamydomonas reinhardtii, et al. 2013, Nucleic Acids Research, 1-15
- Phycobilisome Antenna Deletion in a Cyanobacterium does Not Improve Photosynthetic Energy Conversion Efficiency or Productivity in a Bench-Scale Photobioreactor System, LE Page, et al. 2013, Research for Food, Fuel and the Future
- Phycobilisome antenna truncation reduces photoautotrophic productivity in Synechocystis sp. PCC 6803, a cyanobacterium, LE Page, et al. 2012, Applied and Environmental Microbiology, 79(19)
- Elevated Carbon Dioxide Differentially Alters The Photophysiology Of Thalassiosira Pseudonana (Bacillariophyceae) And Emiliania Huxleyi (Haptophyta), McCarthy A. et al. 2012, J. Phycol., 48: 635–646
- Photosynthetic Efficiency of Chlamydomo Reinhardtii in Attenuated, Flashing Light, Vejrazka C. et al. 2012, Biotechnology and Bioengineering
- Genetic Analysis of the Hox Hydrogenase in the Cyanobacterium Synechocystis sp. PCC 6803 Reveals Subunit Roles in Association, Assembly, Maturation, and Function, C Eckert. et al. 2012, The Journal of Biological Chemistry, 287: 43502-43515.
- Reduction of Photoautotrophic Productivity in the Cyanobacterium Synechocystis sp. Strain PCC 6803 by Phycobilisome Antenna Truncation, Page L. E. et al. 2012, Appl. Environ. Microbiol. 78(17): 6349-6351
- Growth of oil accumulating microalga Neochloris oleoabundans under alkaline–saline conditions, Santos A.M. et al. 2012, Bioresource Technology, 104:593-599
- On the dynamics and constraints of batch culture growth of the cyanobacterium Cyanothece sp. ATCC 51142, Sinetova M.A. et al. 2012, Journal of Biotechnology
- Modelling and simulation of photosynthetic microorganism growth: Random walk vs. Finite difference method, Papáček S. et al. 2012, Mathematics and Computers in Simulation, 82(10): 2022-2032
- Photosynthetic Efficiency of Chlamydomonas reinhardtii in Flashing Light, Vejrazka C. et al. 2011, Biotechnology and Bioengineering, 108(12):2905-2913
- A revised mineral nutrient supplement increases biomass and growth rate in Chlamydomonas reinhardtii, Kropat J. et al. 2011, The Plant Journal, 66:770-780
- The Selectivity of Milking of Dunaliella salina, Kleinegris D. et al. 2010, Mar Biotechnol, 12:14-23
- Experimental validation of a nonequilibrium model of CO2 fluxes between gas, liquid medium, and algae in a flat-panel photobioreactor, Nedbal L. et al. 2010, J Ind Microbiol Biotechnol, 37: 1319-1326
- Metabolic rhythms of the cyanobacterium Cyanothece sp. ATCC 51142 correlate with modeled dynamics of circadian clock, J Červený, L Nedbal, 2009, Journal of Biological Rhythms, 24(4): 295-303
- Photobioreactor for cultivation and real-time,in-situ measurement of O2 and CO2 exchange rates, growth dynamics, and of chlorophyll fluorescence emission of photoautotrophic microorganisms, J Červený, et al. 2009, Eng. Life Sci. 9(3): 247-253
- A photobioreactor system for precision cultivation of photoautotrophic microorganisms and for high-content analysis of suspension dynamics, L Nedbal, et al. 2008, Biotechnology and Bioengineering, 100(5): 902-910
