当前位置 > 首页 > 技术文章 > FL3500双调制叶绿素荧光仪部分参考文献
浏览次数:6013 发布日期:2019-3-4  来源:本站 仅供参考,谢绝转载,否则责任自负
FL3500双调制叶绿素荧光仪 (新升级型号为FL6000)​
FL3500双调制叶绿素荧光仪是专门用于对蓝绿藻或绿藻等微藻,叶绿体或类囊体悬浮物,乃至叶片进行光合作用研究的强大科研工具。仪器具备双通道测量控制,可控制测量样品的温度,并配备单翻转光(STF),内置多种可用户自行修改的测量程序,可进行目前国际上对于叶绿素荧光的各种深入机理研究。其核心结构是包含了一个悬浮液标准样品杯的光学测量头,内置3组LED光源和1个500 kHz/16位AD 转换的PIN二极管信号检测器。AD转换的增益和积分时间可以通过软件控制。检测器测量叶绿素荧光信号的时间分辨率可高达4 µs(快速版为1µs)。系统配置的光合放氧测量模块,使其可以对放氧复合物的状态转换做更深入研究。
FL3500叶绿素荧光仪配备有4种测量室:标准版、快速版、叶夹版、水下版。主机为双通道设计,可同时连接任意两种测量室,大大扩展了叶绿素荧光测量的应用范围,可以对任何类型的植物样品进行叶绿素荧光测量。
1.Manaa A., et al. (2019) Salinity tolerance of quinoa (Chenopodium quinoa Willd) as assessed by chloroplast ultrastructure and photosynthetic performance. Environmental and Experimental Botany, Volume 162, Pages 103-114
2.Sicora C. I., et al. (2019) Regulation of PSII function in Cyanothece sp. ATCC 51142 during a light–dark cycle. Photosynthesis Research, Volume 139, Issue 1–3, pp 461–473
3.Smythers A. L., et al. (2019) Characterizing the effect of Poast on Chlorella vulgaris, a non-target organism. Chemosphere, Volume 219, Pages 704-712
4.Albanese P., et al. (2018) Thylakoid proteome modulation in pea plants grown at different irradiances: quantitative proteomic profiling in a non‐model organism aided by transcriptomic data integration. The Plant Journal, Volume96, Issue4, Pages 786-800
5.Antal T., Konyukhov I., Volgusheva A., et al. (2018) Chlorophyll fluorescence induction and relaxation system for the continuous monitoring of photosynthetic capacity in photobioreactors. Physiol Plantarum. DOI: 10.1111/ppl.12693
6.Antal T. K., Maslakov A., Yakovleva O. V., et al. (2018). Simulation of chlorophyll fluorescence rise and decay kinetics, and P700-related absorbance changes by using a rule-based kinetic Monte-Carlo method. Photosynthesis Research. DOI:10.1007/s11120-018-0564-2
7.Biswas S., Eaton-Rye J. J. (2018). PsbY is required for prevention of photodamage to photosystem II in a PsbM-lacking mutant of Synechocystis sp. PCC 6803. Photosynthetica, 56(1), 200–209.
8.Bonisteel E. M., et al. (2018). Strain specific differences in rates of Photosystem II repair in picocyanobacteria correlate to differences in FtsH protein levels and isoform expression patterns. PLoS ONE 13(12): e0209115.
9.Fang X., et al. (2018). Transcriptomic responses of the marine cyanobacterium Prochlorococcus to viral lysis products. Environmental Microbiology, doi: 10.1101/394122.
10.Hanelt D. (2018). Photosynthesis assessed by chlorophyll fluorescence. Bioassays, Elsevier, Pages 169-198.
11.Kuthanová Trsková E., Belgio E., Yeates A. M., et al. (2018) Antenna proton sensitivity determines photosynthetic light harvesting strategy, Journal of Experimental Botany, Volume 69, Issue 18, 14 August 2018, Pages 4483–4493
12.Liefer J. D., Garg A. Campbell D. A., et al. (2018) Nitrogen starvation induces distinct photosynthetic responses and recovery dynamics in diatoms and prasinophytes. PLoS ONE. DOI: 10.1371/journal.pone.0195705
13.Malerba M. E., Palacios M. M., Palacios Delgado Y. M., et al. (2018) Cell size, photosynthesis and the package effect: an artificial selection approach. New Phytologist. DOI: 10.1111/nph.15163
14.Patel V. K., et al. (2018) Characterization of Seven Species of Cyanobacteria for High-Quality Biomass Production. Arabian Journal for Science and Engineering, Volume 43, Issue 1, pp 109–121
15.Pavlou A., Jacques J., Ahmadova N., Mamedov F., & Styring S. (2018). The wavelength of the incident light determines the primary charge separation pathway in Photosystem II. Scientific Reports, 8(1). DOI:10.1038/s41598-018-21101-w
16.Perkins R., Williamson C., Lavaud J., et al. (2018) Time-dependent upregulation of electron transport with concomitant induction of regulated excitation dissipation in Haslea diatoms. Photosynth Res. DOI: 10.1007/s11120-018-0508-x
17.Poulin C., D. Antoine, and Y. Huot. (2018). Diurnal variations of the optical properties of phytoplankton in a laboratory experiment and their implication for using inherent optical properties to measure biomass," Opt. Express 26, 711-729.
18.Semin B. K., Davletshina L. N., & Mamedov M. D. (2017). Effect of different methods of Ca2+ extraction from PSII oxygen-evolving complex on the QA− oxidation kinetics. Photosynthesis Research, 136(1), 83–91.
19.Spijkerman E., Behrend H., Fach B., & Gaedke U. (2018). Decreased phosphorus incorporation explains the negative effect of high iron concentrations in the green microalga Chlamydomonas acidophila. Science of The Total Environment, 626, 1342–1349.
20.Solhaug K. A., Chowdhury D. P., & Gauslaa Y. (2018). Short- and long-term freezing effects in a coastal (Lobaria virens) versus a widespread lichen (L. pulmonaria). Cryobiology, 82, 124–129.
21.Takagi D., Ifuku K., Nishimura T. and Miyake C. (2018) Antimycin A inhibits cytohrome b559-mediated cyclic electron flow within photosystem II. Photosynth Res. DOI: 10.1007/s11120-018-0519-7
22.Ungerer J., Lin P-C., Chen H-Y., Pakrasi H. B. (2018) Adjustments to photosystem stoichiometry and electron transfer proteins are key to the remarkably fast growth of the cyanobacterium Synechococcus elongatus UTEX 2973. mBio 9:e02327-17.
23.Xu K., Lavaud J., Perkins R., Austen E., Bonnanfant M., & Campbell D. A. (2018). Phytoplankton σPSII and Excitation Dissipation; Implications for Estimates of Primary Productivity. Frontiers in Marine Science, 5. DOI:10.3389/fmars.2018.00281
24.Yu Z., et al. (2018) Physiological changes in Chlamydomonas reinhardtii after 1000 generations of selection of cadmium exposure at environmentally relevant concentrations. Environmental Science: Processes & Impacts, DOI:10.1039/C8EM00106E
25.Yu Z., et al. (2018) Effects of TiO2, SiO2, Ag and CdTe/CdS quantum dots nanoparticles on toxicity of cadmium towards Chlamydomonas reinhardtii. Ecotoxicology and Environmental Safety, Volume 156, Pages 75-86
26.Yussi M. Palacios, Avigad Vonshak, and John Beardall (2018) Photosynthetic and growth responses of Nannochloropsis oculata (Eustigmatophyceae) during batch cultures in relation to light intensity. Phycologia: 2018, Vol. 57, No. 5, pp. 492-502.
27.Ahmadova N., Ho F., Styring S. and Mamedov F. (2017) Tyrozine D oxidation and redox equilibrium in Photosystem II. BBA – Bioenergetics.  DOI:10.1016/j.bbabio.2017.02.011
28.Albanese P., et al. (2017) Pea PSII-LHCII supercomplexes form pairs by making connections across the stromal gap. Scientific Reports, 7: 10067, DOI:10.1038/s41598-017-10700-8
29.Belgio E., Trsková E., Kotabová E., et al. (2017) High light acclimation of Chromera velia points to photoprotective NPQ. Photosynth Res. DOI: 10.1007/s11120-017-0385-8
30.Bernát G., Steinbach G., Kaňa R. et al. (2017). On the origin of the slow M–T chlorophyll A fluorescence decline in cyanobacteria: interplay of short-term light-responses. Photosynth Res. DOI: 10.1007/s11120-017-0458-8
31.Chiş C., Carmel D., Chiş I. et al. (2017) Expression of psbA1 gene in Synechocystis sp. PCC 6803 is influenced by CO2. Open Life Sci. DOI: 10.1515/biol-2017-0018
32.Felcmanová K., Lukeš M., Kotabová E., et al. (2017) Carbon use efficiencies and allocation strategies in Prochlorococcus marinus strain PCC 9511 during nitrogenlimited growth. Photosynth Res. Volume 134. DOI: 10.1007/s11120-017-0418-3
33.Huokko T., et al. (2017) Role of type 2 NAD (P) H dehydrogenase NdbC in redox regulation of carbon allocation in Synechocystis. Plant Physiology, Vol. 174, pp. 1863–1880
34.Kamalanathan M, Thi Dao L. H., Chaisutyakorna P., et al. (2017) Photosynthetic physiology of Scenedesmus sp. (Chlorophyceae) under photoautotrophic and molasses-based heterotrophic and mixotrophic conditions. Phycologia. 56. No. 6. DOI: 10.2216/17-45.1
35.Li G. and Campbell D. A. (2017) Interactive effects of nitrogen and light on growth rates and RUBISCO content of small and large centric diatoms. Photosynth Res. Volume 131, DOI:10.1007/s11120-016-0301-7
36.Li G., Talmy D. and Campbell D. A. (2017) Diatom growth  responses  to  photoperiod  and  light  are predictable from diel reductant generation. J. Phycol. Volume 53. DOI: 10.1111/jpy.12483
37.Markou G., Dao L. H. T., Muylaert K. and Beardall J.(2017) Influence of different degrees of N limitation on photosystem II performance and heterogeneity of Chlorella vulgaris. Algal Research. Pages 84 – 92. DOI: 10.1016/j.algal.2017.07.005
38.Miyachi M., Ikehira S., Nishior D., et al. (2017) Photocurrent generation of reconstituted photosystem II on self-assembled gold film. Langmuir., Volume 33 (6). DOI: 10.1021/acs.langmuir.6b03499
39.Murphy C. D., et al. (2017) Photoinactivation of Photosystem II in Prochlorococcus and Synechococcus. PLoS ONE, 12(1): e0168991
40.Nath A., et al. (2017) Microalgal consortia differentially modulate progressive adsorption of hexavalent chromium. Physiology and Molecular Biology of Plants, Volume 23, Issue 2, pp 269–280
41.Ni G., et al. (2017) Arctic Micromonas uses protein pools and non-photochemical quenching to cope with temperature restrictions on Photosystem II protein turnover. Photosynthesis Research, Volume 131, Issue 2, pp 203–220
42.Piwosz K., Kaftan D., Dean J., et al. (2017) Nonlinear effect of irradiance on photoheterotrophic activity and growth of the aerobic anoxygenic phototrophic bacterium Dinoroseobacter shibae. Environmental microbiology. DOI: 10.1111/1462-2920.14003
43.Xu K., Grant-Burt J. L., Donaher N. and Campbell D. A. (2017) Connectivity among Photosystem II centers in Phytoplankters: Patterns and Responses. BBA – Bioenergetics. DOI:10.1016/j.bbabio.2017.03.003
44.Zhang X., Ma F., Zhu X., et al. (2017) The acceptor side of photosystem II is the initial target of nitrite stress in Synechocystis sp. strain PCC 6803. Appl Environ Microbiol
45.Dao L. H. T. and Beardall J. (2016)  Effects of lead on two green microalgae Chlorella and Scenedesmus: photosystem II activity and heterogenity.  Algal Research. Volume 16. DOI: 10.1016/j.algal.2016.03.006.
46.Ferroni L., Suorsa M., Aro, E. M., et al. (2016) Light acclimation in the lycophyte Selaginella martensii depends on changes in the amount of photosystems and on the flexibility of the light-harvesting complex II antenna association with both photosystems. New Phytol. Volume 211. DOI: 10.1111/nph.13939
47.Garcia-Chaves M. C., Cottrell M. T., Kirchman D. L. et al. (2016) Single-cell activity of freshwater aerobic anoxygenic phototrophic bacteria and their contribution to biomass  production. The ISME Journal. Volume 10. DOI:10.1038/ismej.2015.242
48.Grama B. S., Agathos S. N. and Jeffryes C. S. (2016) Balancing Photosynthesis and Respiration Increases Microalgal Biomass Productivity during Photoheterotrophy on Glycerol.  ACS Sustainable Chem. Eng. Volume 4. Pages 1611–1618.
49.Kobayashi K., Endo K. and Wada H. (2016) Multiple Impacts of Loss of Plastidic Phosphatidylglycerol Biosynthesis on Photosynthesisduring Seedling Growth of Arabidopsis.  Frontiers of Plant Sciences. Volume 7. DOI: 10.3389/fpls.2016.00336
50.Li G., Woroch A. D., Donaher N. A., Cockshutt A. M., et al. (2016) A Hard Day's Night: Diatoms Continue Recycling Photosystem II in the Dark . Frontiers in Marine Science. Volume 3. DOI: 10.3389/fmars.2016.00218
51.Murphy C. D., Ni G., Li G., et al. (2016) Quantitating active photosystem II reaction center content from fluorescence induction transients. Limnol. Oceanogr. Methods. DOI:10.1002/lom3.10142
52.Patel V. K., Mají D., Pandey S. S., et al. 2016) Rapid budding EMS mutants of Synechocystis PCC 6803 producing carbohydrate or lipid enriched biomass, Algal Research. Volume 16. DOI: 10.1016/j.algal.2016.02.029.
53.Rehman A. U., Szabó M., Deák Z., et al. (2016) Symbiodinium sp. cells produce light-induced intra- and extracellular singlet oxygen, which mediates photodamage of the photosynthetic apparatus and has the potential to interact with the animal host in coral symbiosis. New Phytol. Volume 212. DOI:10.1111/nph.14056
54.Treves H., Raanan H., Kedem I., et al. (2016) The mechanisms whereby the green alga Chlorella ohadii isolated from desert soil crust, exhibits unparalleled photodamage resistence. New Phytologist. 210. DOI : 10.1111/nph.13870
55.Volgusheva A., Kruse O., Styring S., et al. (2016) Changes in the Photosystem II complex associated with hydrogen formation in sulfur deprived Chlamydomonas reinhardtii. Algal Research. Volume 18. DOI: 10.1016/j.algal.2016.06.025.
56.Wang J., Liu Q., Feng J., et al. (2016) Photosynthesis Inhibition of Pyrogallol Against the Bloom-Forming Cyanobacterium Microcystis aeruginosa TY001. Pol. J. Environ. Stud. Volume 25. DOI: 10.15244/pjoes/63412
57.Cheregi O., Kotabová E., Prášil O., et al. (2015) Presence of state transitions in the cryptophyte alga Guillardia theta. Journal of Experimental Botany. Volume 66. Pages 6461–6470.
58.Li, G., Brown, C. M., Jeans, J. A., et al. (2015) The nitrogen costs of photosynthesis in  a diatom under current and future pCO2. New Phytologist. Volume 205. Pages 533–543.
59.Negi S., Barry A. N., Friedland N., et al. (2015). Impact of Nitrogen Limitation on Biomass, Photosynthesis, and Lipid Accumulation in Chlorella Sorokiniana. Journal of Applied Phycology. DOI 10.1007/s10811-015-0652-z
60.You L., He L. and Tang Y. J. (2015). Photoheterotrophic fluxome in Synechocystissp. strain PCC 6803 and its implications for cyanobacterial bioenergetics. Journal of bacteriol Bacteriology. Volume 197. Pages 943–950. DOI:10.1128/JB.02149-14
61.Zorz J. K., Allanach J. R., Murphy C. D., et al. (2015). The RUBISCO to Photosystem II Ratio Limits the Maximum Photosynthetic Rate in Picocyanobacteria. Life. Volume 5. Pages 403–417.  DOI: 10.3390/life5010403
62.Chiş C., Chiş I., Sicora O., et al. (2014). Forwar elektron transport measured in situ in microbibial mats from a hot spring in N-W Romania. Studia Universitatis Babes-Bolyai, Biologia. Volume 59. Pages 17-26.
63.Káňa R., Kotabova E., Lukeš M., et al. (2014). Phycobilisome Mobility and Its Role in the Regulation of Light Harvesting in Red Algae. Plant Physiology. Volume 165. Pages 1618–1631. DOI: 10.1104/pp.114.236075
64.Kotabová, E., Jarešová, J., Kaňa, R., et al. (2014). Novel type of red-shifted chlorophyll a antenna complex from Chromera velia. I. Physiological relevance and functional connection to photosystems. Biochimica et Biophysica Acta – Bioenergetics. Volume 1837. Pages 734-743.
65.Petrou, K., Trimborn, S., Rost, B., et al. (2014). The impact of iron limitation on the physiology of the Antarctic diatom Chaetoceros simplex. Marine Biology. Volume 161. Pages 925-937 .
66.Solhaug K. A., Xie L. and Gauslaa Y. (2014). Unequal allocation of excitation energy between photosystem II and I reduces cyanolichen photosynthesis in blue light. Plant Cell Physiol. Volume 55. Pages 1404-14.
67.K Petrou, S Trimborn,B Rost, PJ Ralph,CS Hassler. The impact of iron limitation on the physiology of the Antarctic diatom Chaetoceros simplex. Marine Biology.April 2014,Volume 161,Issue 4,pp 925-937.
68.A Jajoo, NR Mekala, RS Tomar, M Grieco. Inhibitory effects of polycyclic aromatic hydrocarbons (PAHs) on photosynthetic performance are not related to their aromaticity.Journal of Photochemistry and Photobiology B: Biolagy. August 2014,Volume 137, Pages 151–155
69.E Kotabová, J Jarešová, R Kaňa, R Sobotka. Novel type of red-shifted chlorophyll a antenna complex from Chromeravelia. I. Physiological relevance and functional connection to Photosystems. Biochimica et Biophysica Acta (BBA) - Bioenergetics, Volume 1837, Issue 6, June 2014, Pages 734–743
70.A Belatik, S Hotchandani, R Carpentier. Inhibition of the Water Oxidizing Complex of Photosystem II and the Reoxidation of the Quinone Acceptor QA− by Pb2+. PlOS one.2013 Jul 4; 8(7):e68142.
71.I Hasni, S Hamdani, R Carpentier. Destabilization of the Oxygen Evolving Complex of Photosystem II by Al3+. Photochemistry and Photobiology.2013 Sep-Oct; 89(5):1135-1142.
72.A Tovuu, IS Zulfugarov, CH Lee. Correlations between the temperature dependence of chlorophyll fluorescence and the fluidity of thylakoid membranes. Physiologia plantarum.2013 Apr;147(4):409-16.
73.D Zhang, C Deng,X Pan. Excess Ca2+ does not alleviate but increases the toxicity of Hg2+ to photosystem II in Synechocystis sp.(Cyanophyta). Ecotoxicology and environmental safety.2013 Nov; 97:160-5.74. S OPRIS,R Teodor,C SICORA. Effect on the Electron Transport Chain of Changing Carbon Dioxide Concentration in Some Model Cyanobacteria Species. ProEnvironment/ProMediu. (2013) Vol 6, No 14
74.Jared M. Fraser,Sarah E. Tulk,Jennifer A. Jeans. Photophysiological and photosynthetic complex changes during iron starvation in Synechocystis sp. PCC 6803 and Synechococcus elongatus PCC 7942. PLOS ONE (2013) 8(3): 1-11.
75.É Kiss,PB Kós,M Chen,I Vass. Functioning of the Bidirectional Hydrogenase in Different Unicellular Cyanobacteria. Photosynthesis Research for Food, Fuel and the Future. (2013), pp 733-736.
76.T Krupnik, E Kotabová, LS van Bezouwen. A Reaction Center-dependent Photoprotection Mechanism in a Highly Robust Photosystem II from an Extremophilic Red Alga,
Cyanidioschyzon merolae. Journal of Biological Chemistry.2013 Aug 9; 288(32):23529-42.
77.FL Figueroa, CG Jerez, N Korbee. Use of in vivo chlorophyll fluorescence to estimate photosynthetic activity and biomass productivity in microalgae grown in different culture systems. Latin american journal of aquatic rsearch (2013) 41(5): 801-819
78.R Kaňa, O Komárek, E Kotabová. The Slow S to M fluorescence rise is missing in the RpaC mutant of Synechocystis sp.(PCC 6803) . Photosynthesis Research for Food, Fuel and the Future, 493-496
79.W. Vredenberg and O. Prasil. On the polyphasic quenching kinetics of chlorophyll a fluorescence in algae after light pulse of variable length. Photosynth Research (2013) 117:321-337
80.Krupnik, E Kotabová, LS van Bezouwen. A Reaction Center-dependent Photoprotection Mechanism in a Highly Robust Photosystem II from an Extremophilic Red Alga,
Cyanidioschyzon merolae. T- Journal of Biological Chemistry, 2013 Aug 9;288(32):23529-42.
81.Z Perrine, S Negi, RT Sayre. Optimization of photosynthetic light energy utilization by microalgae. Algal Research. October 2012, Volume1,Issue2, Pages 134–142
82.Y Kato, T Shibamoto, S Yamamoto, T Watanabe. Influence of the PsbA1/PsbA3, Ca2+/Sr2+ and Cl−/Br− exchanges on the redox potential of the primary quinone QA in Photosystem II from Thermosynechococcus elongatus as revealed by spectroelectrochemistry. Biochimca et Biophysica Acta, 2012 Nov; 1817(11):1998-2004.
83.C Deng, X Pan, H Zhang, X Pan. Fire-resistance of six tree species to fire probed by chlorophyll fluorescence. Journal of Food, Agriculture & Environment. 2012, Vol.10 (2): 1329-1333.
84.S Wang, X Pan. Effects of Sb (V) on growth and chlorophyll fluorescence of Microcystis aeruginosa (FACHB-905). Current microbiology.2012 Dec;65(6):733-41.
85.S Wang, D Zhang, X Pan. Effects of arsenic on growth and photosystem II (PSII) activity of Microcystis aeruginosa. Ecotoxicology and environmental safety.2012 Oct; 84:104-11.
86.J Essemine, S Govindachary, D Joly, S Ammar. Effect of moderate and high light on photosystem II function in Arabidopsis thaliana depleted in digalactosyl-diacylglycerol. Biochimica et Biophysica Acta (BBA) - Bioenergetics, August 2012, Volume 1817, Issue 8, Pages 1367–1373.
87.É Kiss, PB Kós, M Chen, I Vass. A unique regulation of the expression of the psbA, psbD, and psbE genes, encoding the D1, D2 and cytochrome b559 subunits of the Photosystem II complex in the chlorophyll d containing cyanobacterium Acaryochloris marina. Biochimica et Biophysica Acta (BBA) - Bioenergetics, July 2012, Volume 1817, Issue 7, Pages 1083–1094.
88.Y Kato, T Shibamoto, S Yamamoto, T Watanabe. Influence of the PsbA1/PsbA3, Ca 2+/Sr 2+ and Cl−/Br− exchanges on the redox potential of the primary quinone QA in Photosystem II from Thermosynechococcus elongatus as revealed by spectroelectrochemistry. Biochimica et Biophysica Acta (BBA) – Bioenergetics. 2012 Nov;1817(11):1998-2004.
89.J Essemine, S Govindachary, S Ammar. Enhanced sensitivity of the photosynthetic apparatus to heat stress in digalactosyl-diacylglycerol deficient Arabidopsis. Environmental and Experimental Botany, August 2012, Pages 16–26
90.S Ding, M Lei, Q Lu, A Zhang, Y Yin, X Wen. Enhanced sensitivity and characterization of photosystem II in transgenic tobacco plants with decreased chloroplast glutathione reductase under chilling stress. Biochimica et Biophysica Acta (BBA) – Bioenergetics.2012 Nov; 1817(11):1979-91.
91.HP Grossart, M Koblížek. Distribution of aerobic anoxygenic phototrophic bacteria in glacial lakes of northern Europe. Aquat Microb Ecol,AME 66:77-86 (2012) .
92.G Torzillo, C Faraloni, AM Silva, J Kopecký. Photoacclimation of Phaeodactylum tricornutum (Bacillariophyceae) cultures grown outdoors in photobioreactors and open ponds.European Journal of Phycology. Volume 47,Issue 2,pages 169-181.
93.Z Li, F Xing, D Xing. Characterization of target site of aluminum phytotoxicity in photosynthetic electron transport by fluorescence techniques in tobacco leaves. Plant and Cell Physiology.2012 Jul;53(7):1295-309.
94.R Kaňa, E Kotabová, R Sobotka , O Práši. Non-photochemical quenching in cryptophyte alga Rhodomonas salina is located in chlorophyll a/c antennae. PlOS one ,2012;7(1):e29700.
95.R Kaňa, E Kotabová, O Komárek, B Šedivá. The slow S to M fluorescence rise in cyanobacteria is due to a state 2 to state 1 transition. Biochimica et Biophysica Acta (BBA) - Bioenergetics, Volume 1817, Issue 8, August 2012, Pages 1237–1247
96.W. Vredenberg, M Durchan and O Prasil. The analysis of PSII photochemical activity using single and multi-turnover excitations. Journal of Photochemistry and Photobiology B: biology (2012) 107: 45-54
97.M Hakala-Yatkin, E Tyystjärvi. Inhibition of Photosystem II by the singlet oxygen sensor compounds TEMP and TEMPD. Biochimica et Biophysica Acta (BBA) - Bioenergetics, 2011 Mar; 1807(3):243-50.
98.N Msilini, M Zaghdoudi, S Govindachary. Inhibition of photosynthetic oxygen evolution and electron transfer from the quinone acceptor QA− to QB by iron deficiency. Photosynthesis Research. 2011 Mar; 107(3):247-56.
99.J Essemine, S Govindachary, S Ammar, S Bouzid. Functional aspects of the photosynthetic light reactions in heat stressed Arabidopsis deficient in digalactosyl-diacylglycerol. Journal of plant Physiology.2011 Sep 1;168(13):1526-33.
100.C Jeanthon, D Boeuf, O Dahan. Diversity of cultivated and metabolically active aerobic anoxygenic phototrophic bacteria along an oligotrophic gradient in the Mediterranean Sea. Biogeosciences Discussions.2011, Vol. 8 Issue 3, p4421-4457. 37p.
101.K Petrou,R Hill, MA Doblin,A McMinn. PHOTOPROTECTION OF SEA‐ICE MICROALGAL COMMUNITIES FROM THE EAST ANTARCTIC PACK ICE1. Journal of Phycology, February 2011,Volume 47,Issue 1,pages 77–86, February 2011
102.SI Allakhverdiev, T Tsuchiya. Redox potentials of primary electron acceptor quinone molecule (QA)− and conserved energetics of photosystem II in cyanobacteria with chlorophyll a and chlorophyll a and chlorophyll d. Proceedings of the National Academy of Sciences of the United States of America.2011 May 10;108(19):8054-8.
103.Z Perrine, R Sayre. Modulating the redox potential of the stable electron acceptor, QB, in mutagenized photosystem II reaction centers. Biochemistry, 2011 Mar 8;50(9):1454-64.
104.K Petrou, MA Doblin, PJ Ralph. Heterogeneity in the photoprotective capacity of three Antarctic diatoms during short-term changes in salinity and temperature. Marine Biology, May 2011 ,Volume 158,Issue 5.pp 1029-1041.
105.M Zaghdoudi, N Msilini, S Govindachary. Inhibition of photosystems I and II activities in salt stress-exposed Fenugreek (Trigonella foenum graecum). Journal of Photochemistry and Photobiology B: Biology,Volume 105, Issue 1, 5 October 2011, Pages 14–20.
106.D Lamy, C Jeanthon, J Ras. Ecology of aerobic anoxygenic phototrophic bacteria along an oligotrophic gradient in the Mediterranean Sea. Biogeosciences Discussions (2011).Vol. 8 Issue 1, p323-354.
107.S Rantamäki, E Tyystjärvi. Analysis of charge recombination with the Arrhenius, Eyring and Marcus theories. Journal of Photochemistry and Photobiology B: Biology.2011 Jul-Aug; 104(1-2):292-300
108.H Liu,JL Roose, JC Cameron, HB Pakrasi. A genetically tagged Psb27 protein allows purification of two consecutive photosystem II (PSII) assembly intermediates in Synechocystis 6803, a cyanobacterium. Journal of Biological Chemistry.2011 Jul 15; 286(28):24865-71.
109.Y Zhang, S Ding, Q Lu, Z Yang, X Wen, L Zhang. Characterization of photosystem II in transgenic tobacco plants with decreased iron superoxide dismutase. Biochimica et Biophysica Acta (BBA) – Bioenergetics.2011 Apr; 1807(4):391-403.
110.A Gauthier, D Joly, S Boisvert. Period‐four Modulation of Photosystem II Primary Quinone Acceptor (QA) Reduction/Oxidation Kinetics in Thylakoid Membranes. Photochemistry and Photobiology,2010 Sep-Oct;86(5):1064-70.
111.T Shibamoto, Y Kato,R Nagao, T Yamazaki, T Tomo. Species-dependence of the redox potential of the primary quinone electron acceptor QA in photosystem II verified by spectroelectrochemistry. FEBS letters ,2010 Apr 16;584(8):1526-30.
112.L Li, X Chen, D Zhang, X Pan. Effects of insecticide acetamiprid on photosystem II (PSII) activity of Synechocystis sp.(FACHB-898) . Pesticide Biochemistry and Physiology.
113.Daoyong Zhang,Xiangliang Pan,Guijin Mu,Jianlong Wang. Toxic effects of antimony on photosystem II of Synechocystis sp. as probed by in vivo chlorophyll fluorescence. Journal of Applied Phycology,August 2010,Volume 22,Issue 4,pp 479-488.
114.L Gunnelius, I Tuominen, S Rantamäki. SigC sigma factor is involved in acclimation to low inorganic carbon at high temperature in Synechocystis sp. PCC 6803. microbiology,2010 Jan; 156(Pt 1):220-9.
115.N Jiao,F Zhang,N Hong. Significant roles of bacteriochlorophylla supplemental to chlorophylla in the ocean. The ISME journal.2010 Apr; 4(4):595-7.
116.B Cai,A Zhang, Z Yang, Q Lu, X Wen, C Lu. Characterization of photosystem II photochemistry in transgenic tobacco plants with lowered Rubisco activase content. Journal of plant physiology, 2010 Nov 15; 167(17):1457-65.
117.M Koblížek, J Mlčoušková, Z Kolber, J Kopecký. On the photosynthetic properties of marine bacterium COL2P belonging to Roseobacter clade. Archives of microbiology, 2010 Jan; 192(1):41-9.
118.X Feng, A Bandyopadhyay, B Berla, L Page. Mixotrophic and photoheterotrophic metabolism in Cyanothece sp. ATCC 51142 under continuous light. Microbiology, 2010 Aug; 156(Pt 8):2566-74.
119.D Bína,R Litvín, F Vácha. Absorbance changes accompanying the fast fluorescence induction in the purple bacterium Rhodobacter sphaeroides. Photosynthesis research, 2010 Aug; 105(2):115-21.
120.X Pan, D Zhang, X Chen, G Mu, L Li, A Bao. Effects of levofloxacin hydrochlordie on photosystem II activity and heterogeneity of Synechocystis sp. Chemosphere ,2009 Oct;77(3):413-8.122. Xiangliang Pan, Xi Chen, Daoyong Zhang, Jianlong Wang, Chunnuan Deng. Effect of chromium (VI) on photosystem II activity and heterogeneity of synechocystis sp.(cyanophyta): studied with in vivo chlorophyll fluorescence tests. Journal of Phycology,Volume 45,Issue 2, pages 386–394,April 2009
121.É Kiss,PB Kós,I Vass. Transcriptional regulation of the bidirectional hydrogenase in the cyanobacterium Synechocystis 6803. Journal of biotechnology, 2009 Jun 1;142(1):31-7.
122.M Pollari, V Ruotsalainen, S Rantamäki. Simultaneous inactivation of sigma factors B and D interferes with light acclimation of the cyanobacterium Synechocystis sp. strain PCC 6803.Journal of Bacteriology, 2009 Jun; 191(12):3992-4001.
123.R Kaňa, O Prášil, O Komárek. Spectral characteristic of fluorescence induction in a model cyanobacterium, Synechococcus sp.(PCC 7942). Biochimica et Biophysica Acta (BBA) - Bioenergetics, 06/2009; 1787(10):1170-8.
124.W. J. Vredenbert. Kinetic models of photosystem II should accommodate the effect of donor side quenching on variable chlorophyll a fluorescence in the microseconds time rang. Photosynth Research (2009) 102:99-101
125.X Pan, C Deng, D Zhang, J Wang, G Mu, Y Chen. Toxic effects of amoxicillin on the photosystem II of Synechocystis sp. characterized by a variety of in vivo chlorophyll fluorescence tests. Aquatic toxicology,2008 Sep 29;89(4):207-13.
126.JL Roose, HB Pakrasi. The Psb27 protein facilitates manganese cluster assembly in photosystem II. Journal of biological chemistry.2008 Feb 15; 283(7):4044-50.
127.M Mašín, J Nedoma, L Pechar. Distribution of aerobic anoxygenic phototrophs in temperate freshwater systems. Environmental Microbiology,2008 Aug; 10(8):1988-96.
128.B Zhao, J Wang, H Gong, X Wen, H Ren, C Lu. Effects of heat stress on PSII photochemistry
in a cyanobacterium Spirulina platensis. Plant science,2008,175(4):556-564.
129.H Gong, Y Tang,J Wang, X Wen, L Zhang,congming Lu. Characterization of photosystem II in salt-stressed cyanobacterial Spirulina platensis cells. Biochimica et Biophysica Acta (BBA) – Bioenergetics. 2008 Jun; 1777(6):488-95.
130.D Eisenstadt, I Ohad, N Keren. Changes in the photosynthetic reaction centre II in the diatom Phaeodactylum tricornutum result in non‐photochemical fluorescence quenching. Environmental microbiology (2008) 10: 1997-2007
131.KM Wegener, EA Welsh, LE Thornton, N Keren. High sensitivity proteomics assisted discovery of a novel operon involved in the assembly of photosystem II, a membrane protein complex. Journal of Biological Chemistry, 2008 Oct 10; 283(41):27829-37.
132.AK Singh, T Elvitigala, M Bhattacharyya-Pakrasi. Integration of carbon and nitrogen metabolism with energy production is crucial to light acclimation in the cyanobacterium Synechocystis. Plant Physiology, 2008 Sep;148(1):467-78.
133.Y. Allahverdiyeva, I Sairanen, etc. Photosynthetic electron transport properties of an uptake Hydrogenase deletion mutant of Nostoc punctiforme PCC 73102. J.F. Allen, E. Gantt, J.H. Golbeck, and B. Osmond (eds.), Photosynthesis. Energy from the Sun: 14th International Congress on Photosynthesis, 3–5. © 2008 Springer.
134.M. O. Piramowicz, R Bock, etc. Binding sites of Cadmium ions within photosystem II. J.F. Allen, E. Gantt, J.H. Golbeck, and B. Osmond (eds.), Photosynthesis. Energy from the Sun: 14th International Congress on Photosynthesis, 311–314. © 2008 Springer.
135.A. Thapper, F. Mamedov and S styring. IR-Induced photochemistry in Photosystem II. J.F. Allen, E. Gantt, J.H. Golbeck, and B. Osmond (eds.), Photosynthesis. Energy from the Sun: 14th International Congress on Photosynthesis, 521–524. © 2008 Springer.
136.A. Orzechowska, R. Bock, etc. Cu2+ binding sites in PSII. J.F. Allen, E. Gantt, J.H. Golbeck, and B. Osmond (eds.), Photosynthesis. Energy from the Sun: 14th International Congress on Photosynthesis, 657–660. © 2008 Springer.
137.P. B. Kos, Z. Deak, etc. Light induced exchange of different psbA gene copies in the Cyanobacterium Thermosynechococcus elongates. J.F. Allen, E. Gantt, J.H. Golbeck, and B. Osmond (eds.), Photosynthesis. Energy from the Sun: 14th International Congress on Photosynthesis, 39–42. © 2008 Springer.
138.K. Cser and I Vass. Regulation of photoprotection by non—radiative charge recombination in photosystem II. J.F. Allen, E. Gantt, J.H. Golbeck, and B. Osmond (eds.), Photosynthesis. Energy from the Sun: 14th International Congress on Photosynthesis, 47–50. © 2008 Springer.
139.K. Cser, Z Deak, etc. Energetics of photosystem II charge recombination in Acaryochloris marina studied by thermoluminescence and flash-induced chlorophyll fluorescence measurements. Photosynth Research (2008) 98: 131-140.
140.M. Hamilton, E. Franco, etc. Cytochrome b-559 is important for modulating electron transfer on the acceptor side of photosystem II and for photoprotection during assembly of the Mn4Ca complex. J.F. Allen, E. Gantt, J.H. Golbeck, and B. Osmond (eds.), Photosynthesis. Energy from the Sun: 14th International Congress on Photosynthesis, 413–417. © 2008 Springer.
141.P. Zhang, C. I. Sicora, etc. Expression of inducible inorganic carbon acquisition complexes is under the control of the FtsH protease in Synechocystis sp. PCC 6803. J.F. Allen, E. Gantt, J.H. Golbeck, and B. Osmond (eds.), Photosynthesis. Energy from the Sun: 14th International Congress on Photosynthesis, 829–833. © 2008 Springer.
142.Z. Deak and I. vass. Oscillating yield of flash-induced chlorophyll fluorescence decay in intact cells of Thermosynechococcus elongatus. J.F. Allen, E. Gantt, J.H. Golbeck, and B. Osmond (eds.), Photosynthesis. Energy from the Sun: 14th International Congress on Photosynthesis, 573–576. © 2008 Springer.
143.JW Guo, JK Guo,Y Zhao, LF Du. Changes of Photosystem II Electron Transport in the Chlorophyll‐deficient Oilseed Rape Mutant Studied by Chlorophyll Fluorescence and Thermoluminescence. Journal of Integrative Plant Biology, 10 MAY 2007
144.M. Stibal, J. Elster, etc. Seasonal and diel changes in photosynthetic activity of the snow alga Chlamydomonas nivalis (Chlorophyceae) from Svalbard determined by pulse amplitude modulation fluorometry. FEMS Microbiol Ecol (2007) 59: 265-273.
145.W. Vredenberg, M. Durchan and O Prasil. On the chlorophyll a fluorescence yield in chloroplasts upon excitation with twin turnover flashes (TTF) and high frequency flash trains. Photosynth Research (2007) 93: 183-192.
146.P Vaczi, M Barták. Photosynthesis of lichen symbiotic alga Trebouxia erici as affected by irradiance and osmotic stress. Biologia plantarum (2006) 50(2):257-264.
147.D Bína, R Litvín, F Vácha, P Šiffel. New multichannel kinetic spectrophotometer–fluorimeter with pulsed measuring beam for photosynthesis research. Photosynthesis research.2006 Jun;88(3):351-6.
148.I Balint, J Bhattacharya, A Perelman, D Schatz. Inactivation of the extrinsic subunit of photosystem II, PsbU, in Synechococcus PCC 7942 results in elevated resistance to oxidative stress. FEBS letters.2006 Apr 3; 580(8):2117-22.
149.H Takahashi, A Watanabe, A Tanaka. Chloroplast NAD kinase is essential for energy transduction through the xanthophyll cycle in photosynthesis. Plant and Cell Physiology, 2006 Dec; 47(12):1678-82.
150.O Shlyk-Kerner, I Samish, D Kaftan, N Holland. Protein flexibility acclimatizes photosynthetic energy conversion to the ambient temperature. Nature,2006 Aug 17;442(7104):827-30..
151.M Koblížek, J Stoń‐Egiert, S Sagan. Diel changes in bacteriochlorophyll a concentration suggest rapid bacterioplankton cycling in the Baltic Sea. FEMS microbiology ecology, 2005 Feb 1; 51(3):353-61.
152.M. Koblizek, J. D. Shih, etc. Sequential assembly of photosynthetic units in Rhodobacter sphaeroides as revealed by fast repetition rate analysis of variable bacteriochlorophyll a fluorescence. Biochimica et Biophysica Acta (2005) 1706: 220-231
153.X Wen, H Gong, C Lu. Heat stress induces a reversible inhibition of electron transport at the acceptor side of photosystem II in a cyanobacterium Spirulina platensis. Plant science, 06/2005;
154.R Litvín, D Bína, P Šiffel, F Vácha. Conformational changes and their role in non-radiative energy dissipation in photosystem II reaction centres. Photochemical & Photobiological Sciences, 2005 Dec; 4(12):999-1002.
155.G Parésys, C Rigart, B Rousseau, AWM Wong, F Fan. Quantitative and qualitative evaluation of phytoplankton communities by trichromatic chlorophyll fluorescence excitation with special focus on cyanobacteria. Water research, 2005 Mar;39(5):911-21.
156.N Inoue-Kashino, Y Kashino, K Satoh, I Terashima. PsbU provides a stable architecture for the oxygen-evolving system in cyanobacterial photosystem II. Biochemistry, 2005 Sep 13;44(36):12214-28.
157.JC Cadoret, B Rousseau, I Perewoska, C Sicora. Cyclic nucleotides, the photosynthetic apparatus and response to a UV-B stress in the cyanobacterium Synechocystis sp. PCC 6803.Journal of Biological Chemistry ,2005 Oct 7;280(40):33935-44.
158.N Keren, M Liberton, HB Pakrasi. Photochemical competence of assembled photosystem II core complex in cyanobacterial plasma membrane. Journal of Biological Chemistry, 2005 Feb 25;280(8):6548-53.
159.LE Thornton, N Keren, I Ohad, HB Pakrasi. Physcomitrella patens and Ceratodon purpureus, mosses as model organisms in photosynthesis studies. Photosynthesis research, 2005; 83(1):87-96.
160.KGV Sigfridsson, G Bernát,F Mamedov. Molecular interference of Cd 2+ with Photosystem II.Biochimica et Biophysica Acta (BBA) - Bioenergetics, 2004 Nov 4; 1659(1):19-31.
161.M. L. Dudley Page, P. P. Hamel, etc. A homolog of Prokaryotic Thiol disulfide transporter CcdA is required for the assembly of the Cytochrome b6f complex in Arabidopsis Chloroplasts. The Journal of Biological Chemistry (2004) 279: 32474-32482.
162.R Kaňa, M Špundová, P Ilık, D Lazár, K Klem. Effect of herbicide clomazone on photosynthetic processes in primary barley (Hordeum vulgare L.) leaves. Pesticide Biochemistry and Physiology,Volume 78, Issue 3, March 2004, Pages 161–170.
163.JL Roose, HB Pakrasi. Evidence that D1 processing is required for manganese binding and extrinsic protein  assembly into photosystem II. Journal of Biological Chemistry,11/2004; 279(44):45417-22.
164.Y. Allahverdiyeva, Z. Deak, etc. The function of D1-H332 in photosystem II electron transport studied by thermoluninescence and chlorophyll fluorescence in site-directed mutants of Synechocystis 6803. Eur. J. Biochem. (2004) 271: 3523-3532.
165.C. Sicora, Z. Mate and I. Vass. The interaction of visible and UV-B light during photodamage and repair of Photosystem II. Photosynthesis Research (2003) 75: 127-137
166.M. Koblizek, O. Beja, etc. Isolation and characterization of Erythrobacter sp. Strains from the upper ocean. Arch Microbiol (2003) 180: 327-338
167.J. Kromkamp and R. M. Forster. The used of variable fluorescence measurements in aquatic ecosystems: differences between multiple and single turnover measuring protocols and suggested terminology. Eur. J. Phycol. (2003) 38: 103-112.
168.T Suzuki,J Minagawa, T Tomo. Binding and functional properties of the extrinsic proteins in oxygen-evolving photosystem II particle from a green alga, Chlamydomonas reinhardtii having his-tagged CP47. Plant and cell Physiology, 2003 Jan; 44(1):76-84.
169.M Tichý, L Lupınková,C Sicora,I Vass. Synechocystis 6803 mutants expressing distinct forms of the Photosystem II D1 protein from Synechococcus 7942: relationship between the psbA coding region and sensitivity to visible and UV-B radiation. Biochimica et Biophysica Acta (BBA) - Bioenergetics, 2003 Aug 18;1605(1-3):55-66
170.KM Halverson, BA Barry. Sucrose and glycerol effects on photosystem II. Biophysical journal, 2003 Aug;85(2):1317-25.
171.T Varsano, D Kaftan, U Pick. Effects of iron deficiency on thylakoid membrane structure and composition in the alga Dunaliella salina. Journal of plant nutrition,2003,26 (10 /11) : 2197-2210.
172.L Lupı́nková, JG Metz, BA Diner,I Vass. Histidine residue 252 of the Photosystem II D1 polypeptide is involved in a light-induced cross-linking of the polypeptide with the α subunit of cytochrome b-559: study of a site-directed mutant of Synechocystis PCC 6803. Biochimica et Biophysica Acta (BBA) - Bioenergetics, 2002 Jul 1; 1554(3):192-201
173.J Komenda, L Lupinkova. Absence of the psbH gene product destabilizes photosystem II complex and bicarbonate binding on its acceptor side in Synechocystis PCC 6803. European Journal of Biochemistry, 2002 Jan; 269(2):610-9.
174.D Kaftan, V Brumfeld, R Nevo, A Scherz. From chloroplasts to photosystems: in situ scanning force microscopy on intact thylakoid membranes. The EMBO Journal, 2002 Nov 15; 21(22):6146-53.
175.R Kaňa, D Lazár, O Prášil, J Nauš. Experimental and theoretical studies on the excess capacity of Photosystem II. Photosynthesis research, 2002; 72(3):271-84.
176.C Steglich, M Behrenfeld, M Koblizek. Nitrogen deprivation strongly affects Photosystem II but not phycoerythrin level in the divinyl-chlorophyll b-containing cyanobacterium Prochlorococcus marinus. Biochimica et Biophysica Acta (BBA) - Bioenergetics, 1503 (2001), pp. 341-349
177.M. Koblizek, D. Kaftan and L. Nedbal. On the relationship between the non-photochemical quenching of the chlorophyll fluorescence and the photosystem II light harvesting efficiency. A repetitive flash fluorescence induction study. Photosynthesis Research (2001) 68: 141-152
178.RE Regel, NB Ivleva, H Zer, J Meurer. Deregulation of electron flow within photosystem II in the absence of the PsbJ protein. Journal of Biological Chemistry ,2001 Nov 2; 276(44):41473-8.
179.J Kalina, O Urban, M Čajánek, I Kurasová, V Špunda. Different responses of Norway spruce needles from shaded and exposed crown layers to the prolonged exposure to elevated CO2 studied by various chlorophyll a Fluorescence Techniques. Photosynthetica, 2001,Volume 39,Issue 3,pp 369-376.
180.H Ohkawa, HB Pakrasi, T Ogawa. Two Types of Functionally Distinct NAD (P) H Dehydrogenases inSynechocystis sp. Strain PCC6803. Journal of Biological Chemistry, 2000 Oct 13; 275(41):31630-4.
181.J Skotnica, M Matoušková, J Nauš, D Lazár. Thermoluminescence and fluorescence study of changes in Photosystem II photochemistry in desiccating barley leaves. Photosynthesis Research,2000; 65(1):29-40.
182.E Zak, HB Pakrasi. The BtpA protein stabilizes the reaction center proteins of photosystem I in the cyanobacterium Synechocystis sp. PCC 6803 at low temperature. Plant physiology, 2000 May; 123(1):215-22.
183.NB Ivleva, SV Shestakov, HB Pakrasi. The carboxyl-terminal extension of the precursor D1 protein of photosystem II is required for optimal photosynthetic performance of the cyanobacterium Synechocystis sp.PCC6803. Plant physiology, 2000 Nov; 124(3):1403-12.
184.J Soukupova, A Lukavska, J Lukavský, L Nedbal. Sensitivity of the algal biotest ISO 10253 to the photosystem 2 herbicides in seawater. Photosynthetica, 08/1999; 37(2):209-216.
185.D Kaftan, T Meszaros, J Whitmarsh. Characterization of photosystem II activity and heterogeneity during the cell cycle of the green alga Scenedesmus quadricauda. Plant physiology, 1999 Jun; 120(2):433-42.
186.E. Setlikova, D. Sofrova, etc. Integrity and activity of photosystem 2 complexes isolated from the thermophilic cyanobacterium Synechococcus elongatus using various detergents. Photosynthetica (1999) 37(2): 183-200.
187.L. Nedbal, M. Trtilek and D. Kaftan. Flash fluorescence induction: a novel method to study regulation of Photosysntem II. J. Photochem. Photobiol. B: Biol. (1999) 48: 154-157
188.M Meetam, N Keren, I Ohad, HB Pakrasi. The PsbY protein is not essential for oxygenic photosynthesis in the cyanobacterium Synechocystis sp. PCC 6803. Plant physiology, 1999 Dec; 121(4):1267-72.
189.M. Koblizek, M. Ciscato, etc. Photoadaptation in the green alga Spongiochloris sp. A three-fluorometer study. Photosynthetica (1999) 37(2): 307-323
190.M. Ritz, K. V. Neverov and A. L. Etienne. ΔpH-dependent fluorescence quenching and its photoprotective role in the unicellular red alga Rhodella violacea. Photosynthetica (1999) 37(2): 267-280
191.N. Dijkman, D. Kaftan, M. Trtilek and L. Nedbal. Measurements of phytoplankton of sub-nanomolar chlorophyll concentrations by a modified double-modulation fluorometer. Photosynthetica (1999) 37(2): 249-254
192.O. Urban, M. Trtilek, etc. Single-turnover flashes to saturate the QA reduction in a leaf were generated by the light-emitting diodes from a double modulation kinetic chlorophyll fluorometer. Photosynthetica (1999) 37(2): 201-207
193.TS Feild, L Nedbal, DR Ort. Nonphotochemical reduction of the plastoquinone pool in sunflower leaves originates from chlororespiration. Plant Physiology, 1998 Apr; 116(4):1209-18.
194.M. Koblizek, M. Marek, etc. Light adaptation in the cyanobacterium Synechococcus sp. PCC 7942 measured by the dual-modulation fluorometer. J. Luminescence (1997) 72-74: 589-590.
195.M. Trtilek, D. M. Kramer, etc. Dual-modulation LED kinetic fluorometer. J. of Luminescence (1997) 72-74: 597-599
来源:北京易科泰生态技术有限公司
联系电话:18210150760
E-mail:sales@eco-tech.com.cn
