默瑞热线:4006-400-850
售前咨询:info@moreybio.com
产品订购:order@moreybio.com
售后支持:tech@moreybio.com
默瑞官网:www.moreybio.com
On-bead Digestion:从免疫沉淀到质谱分析
免疫沉淀蛋白及其相互作用物到质谱分析的转移率应尽可能高。这对于低丰度的蛋白质尤其重要。
通过使用on-bead-digestion,您能够:
·节省时间——你不需要洗提结合蛋白质
·保持蛋白质高浓度——不要稀释你的样品
·更少的洗涤步骤能更好的保留Co-IP的相互作用物
胰蛋白酶
对Nano-Traps (GFP-Trap, RFP-Trap, mNeonGreen-Trap, MBP-Trap, GST-Trap,等)的消化会产生少量的缩氨酸。这是由于固定化的羊驼抗体的小尺寸(14 kDa)导致的。例如,用胰蛋白酶对GFP-Trap进行on-bead-digestion只产生4个缩氨酸。
这并不是唯一的优势:由于它们的高亲和力和低背景,ChromoTek的Nano-Traps具有非凡的IP/ Co-IP性能。
ChromoTek的Nano-Traps是分离自羊驼单域抗体(VHHs,也称为纳米体)。因此,它们缺乏抗体轻链,产生更纯粹的IP/ Co-IP结果。
„The best results were obtained by direct tryptic digest of the material on beads followed by mass spectrometry”, Zoltan Lipinszki et al. (2014)
ChromoTek GFP-Trap的on-bead-digestion protocol请点击下方查看:
参考文献:
1. Arne H. Smits, Pascal W. T. C. Jansen, Ina Poser, Anthony A. Hyman, Michiel Vermeulen; Stoichiometry of chromatin-associated protein complexes revealed by label-free quantitative mass spectrometry-based proteomics. Nucleic Acids Res 2013; 41 (1): e28. doi: 10.1093/nar/gks941
2. Zoltan Lipinszki, Peng Wang, Rhys Grant, Catherine Lindon, Nikola S. Dzhindzhev, Pier Paolo D’Avino, Marcin R. Przewloka, David M. Glover, Vincent Archambault; Affinity Purification of Protein Complexes from Drosophila Embryos in Cell Cycle Studies. Methods Mol Biol. 2014;1170:571-88. doi: 10.1007/978-1-4939-0888-2_33.
3. Susan L. Kloet, Matthew M. Makowski, H. Irem Baymaz, Lisa van Voorthuijsen, Ino D. Karemaker, Alexandra Santanach, Pascal W.T.C. Jansen, Luciano Di Croce, Michiel Vermeulen; The dynamic interactome and genomic targets of Polycomb complexes during stem cell differentiation. Nat Struct Mol Biol. 2016 July ; 23(7): 682–690. doi:10.1038/nsmb.3248
4. Benedetta Turriziani, Amaya Garcia-Munoz, Ruth Pilkington, Cinzia Raso, Walter Kolch, Alexander von Kriegsheim; On-Beads Digestion in Conjunction with Data-Dependent Mass Spectrometry: A Shortcut to Quantitative and Dynamic Interaction Proteomics. Biology 2014, 3(2), 320-332; doi:10.3390/biology3020320
