当前位置 > 首页 > 技术文章 > 实验室玻璃仪器名称中英文对照
实验室玻璃仪器名称中英文对照
浏览次数:13525 发布日期:2009-2-5  来源:本站 仅供参考,谢绝转载,否则责任自负
大口杯/烧杯beaker
玻璃烧杯glass beaker
聚四氟乙烯烧杯ptfe griffin beaker
塑料烧杯plastic beaker
不锈钢杯stainless-steel beaker
玻璃瓶flask
三角瓶conical flask
具塞三角瓶conical flask with stopper
支管蒸馏烧瓶distilling flask
凯氏烧瓶kjeldahl flask
抽滤瓶accessory flask with side arm
碘量瓶flask iodine
盘、皿、罐、坩埚dish/jar/crucible
表面皿watch glass
带柄表面皿watch glass with handle
砂心坩埚gooch filtering crucible
称量皿low-form weighing bottle
称量瓶weighing bottle
研磨钵clear glass mortar
研磨棒clear glass pestle
玛瑙研钵agate mortar
玛瑙研磨棒agate pestle
瓷坩埚coors porcelain crucible
过滤瓷坩埚coors porcelain gooch filtering crucible
蒸发皿coors porcelain porcelain dish
具柄蒸发皿coors porcelain casserole
铝盒aluminium specimen box
容器bottle
白细口瓶flint glass solution bottle with stopper
棕细口瓶 brown glass solution bottle with stopper
白广口瓶flint glass solid bottle with stopper
棕色滴瓶brown glass dr-opping bottle
白色滴瓶flint glass dr-opping bottle
塑料洗瓶plastic wash bottle
漏斗funnel & separation
三角漏斗funnel
瓷布氏漏斗coors filtering crucible for bitumens
布氏砂心漏斗buchner funnerl with fritted disc
球形分液漏斗globe-shaped funnel
梨形分液漏斗pear-shaped funnel
小滴管dr-opper
蒸发、冷凝、抽提器condensor & extractor
索氏抽提装置soxhlet apparatus with allihn condenser
抽提筒soxhlet extraction tube
抽提冷凝管allihn condenser wih straight outlet tube
球形冷凝管economical allihn condenser
蛇形冷凝管graham condenser
直形冷凝管 condenser distillation column
逆流冷凝管reflux condenser
蒸馏装置distilling apparatus
旋转蒸发器rotary evaporator
石油产品蒸馏仪petroleum distilling apparatus
试验管tube
比色管毛细管glass microbore tube
筛选设备filtration
标准筛test sieve
震动筛lab sieve shaker
常备用品lab. fitting equipment
玻璃棒glass stirring rod
三口连接管tube with two joints
牛角弯头vacuum connecting tube
温度计套管bevel-seal inlet adapter
干燥器desiccator
真空干燥器vacuum-pressure desiccator
酒精灯alcohol burner
酒精喷灯blast alcohol burner
升降台lab jack
三角架clay pipe iron-wire triangle
铁架台iron support
万能夹extension clamp
蝴蝶夹double-buret clamp
双顶丝clamp regular holder
止水夹flatjaw pinchcock
圆形漏斗架cast-iron ring
移液管架pipet rack
滴水架dry rack
试管架tube rack
比色管架沸石boiling stone
橡胶管rubber tubing
真空泵管tygon vacuum tubing
透明pvc管clear pvc tubing
橡胶塞rubber stopper
吸耳球bulb for pipet
乳胶帽漏斗刷funnel or graduate brush
试剂瓶刷bottle brush
离心管刷centrifuge tube brush
滴定管刷buret brush
试管刷tube brush
比色管刷nessler tube brush
容量瓶刷volumetric flask brush
烧杯刷beaker brush
移液管刷brush for transfer pipets
取样篮collapsible carrier
密封样品袋seal sample bag
药匙lab spoon
镊子forceps
坩埚钳crucible tong
剪刀scissor
打孔器stopper borer
石棉网asbestos-free wire gauze
电炉丝wire coil for heater
脱脂棉absorbent cottonph
 试纸(广泛) universal ph indicator paper
圆形定性滤纸qualitative grade filter circles
方形定性滤纸qualitative grade rectangular filter sheets
称量纸weighing paper
擦镜纸wiper for lens
标签纸 paper label
样品推车lab cart
定时钟traceable timer
秒表stopwatch
油脂取样器oil sampler
液体取样器liquid sampler
原粮扦样器needle-point sampler
取样铲 scoop
煤气灯bunsen burner
计量仪器measuring instrument
移液器pipette/spatula
刻度移液管graduated pipette
大肚移液管volumetric pipet
微量进样器microliter syringe
定量加液器bottle- top dispenser
容量瓶flask volumetric
白容量瓶flint glass flask volumetric
棕色容量瓶brown glass flask volumetric
量筒volumetric cylinder
量筒measuring cylinder
具塞量筒mixing cylinder with stopper
量杯glass graduates with scale滴定仪器burette/dispenser/titration
白滴定管(酸) flint glass burette with glass stopcock
棕色滴定管(酸) brown glass burette with glass stopcock
白滴定管(碱) flint glass burette for alkali
棕色滴定管(碱) brown glass burette for alkali
聚四氟乙烯旋塞滴管flint glass burette with ptfe stopcock
数显半自动滴定仪digital buret
自动滴定仪automatic titrator
其他others
比重瓶specific gravity bottle水
银温度计mercury-filled thermometer
红水温度计red-spirit-filled thermometer
精密温度计fractional-degree thermometer
石油密度计hydrometerph计ph meter
折光仪refractometer
天平analytical balance
电导率仪分光光度计真空泵vacuum pump
冷、热浴bath循环冷却器refrigerating circulator
数显循环水浴锅digital circulating water bath
循环加热器heating circulator
高温加热器(油浴) high-temperature circulator(oil bath)
加热水浴锅digital heating circulating water bath
往复振荡水浴锅reciprocating shaker bath
离心机centrifuge
劳动防护用品safety equip.
全棉工作服cotton lab coat
袖套dafety sleevelet
口罩respirator
工作鞋footware
隔热手套heat insulation gloves
防护眼镜safety spectacle
耐酸碱手套anti-erode glove
防毒面具respirator
安全帽motorcycle safety helmet
洗眼器eyewash equipment
急救药箱first aid pyxides
消防器材fire protection equipment
洗涤用品 things for washing
防滑垫lab mat
粉碎搅拌设备mill & mixer
振荡器shaker
粉碎磨cyclone sample mill
剪切磨cutting mill
磁力搅拌器magnetic stirrer
电动搅拌器power basic stirrer
数显电热搅拌器digital stirring hotplate
加热、制冷设备heating/refrigeration
烘箱oven
闪点仪flash point tester
马弗炉furnace
万用电炉wire coil heater
微波炉电热套heating mantle
冰箱refrigerator
