当前位置 > 首页 > 技术文章 > 硬山核桃幼树叶片黄酮醇浓度对养分施肥的响应
浏览次数:902 发布日期:2022-5-10  来源:本站 仅供参考,谢绝转载,否则责任自负
热点
以白僵菌为材料,对生长分化平衡假说(GDBH)进行了检验。
对黄酮醇,观察到GDBH预测的非线性“驼峰形”反应。
在低碳和黄酮醇的高可用性分配中。
摘要
生长分化平衡假说(GDBH)假设,类黄酮等植物次生代谢物(PSMs)与氮(N)有效性之间存在非线性“驼峰”反应。当氮的有效性至少达到五个水平时,这种反应最容易被检测到,但很少有直接或间接测试GDBH的研究使用了三个或更多水平。50棵白桦(marula)幼树(平均基径 = 35.5  mm,扫描电镜 = 0.52; 平均高度 = 80.9 cm,扫描电镜 = 1.02),随机分配到果园中的五种肥料施用率。在生长季节,每两个月向每棵树苗施用含有缓释硝酸盐的肥料[N:P:K(3:1:5)(26)],作为追肥,其施用量相当于0、20、40、80和120 G N M−2.在生长季节,每两个月使用Dualex®系列4仪器间接测量一次每棵树苗30–35片最近成熟叶片的平均黄酮含量。观察到GDBH预测的非线性“驼峰形”响应,表明在高和低养分有效性条件下,碳分配给PSM的范围比在中等养分有效性条件下更为有限。二次响应的成功检测可能是通过仅测量黄酮醇,这是S.birrea中的主要PSM,以及在肥力极低的土壤上进行试验来实现的。
Foliar flavonol concentration in Sclerocarya birrea saplings responds to nutrient fertilisation according to growth-differentiation balance hypothesis
Highlights
Growth-differentiation balance hypothesis (GDBH) was tested on Sclerocarya birrea.
Nonlinear ‘hump-shaped’ response predicted by GDBH was observed for flavonols.
Allocation of carbon to flavonols limited at low and high nutrient availability.
Abstract
The growth-differentiation balance hypothesis (GDBH) postulates a nonlinear, ‘hump-shaped’ response of plant secondary metabolites (PSMs), such as flavonoids, in relation to nitrogen (N) availability. The response is most easily detected when there are at least five levels of N availability, but very few studies that directly or indirectly tested the GDBH have used three or more levels. Fifty Sclerocarya birrea (marula) saplings (mean basal diameter = 35.5 mm, SEM = 0.52; mean height = 80.9 cm, SEM = 1.02), were randomly assigned to five fertiliser application rates in an orchard. Fertilizer [N:P:K (3:1:5) (26)] containing slow release nitrate was applied to each sapling as a top dressing every two months during the growing season at rates equivalent to 0, 20, 40, 80 and 120 g N m−2. Average flavonoid content of 30–35 recently matured leaves per sapling was indirectly measured every two months during the growing season using the Dualex® Series 4 instrument. The nonlinear, ‘hump-shaped’ response predicted by GDBH was observed, indicating that allocation of carbon to PSMs was more limited at both high and low nutrient availability than at intermediate nutrient availability. Successful detection of the quadratic response was probably facilitated by only measuring flavonols, which are the main PSMs in S. birrea, and by conducting the experiment on soils of very low fertility.
Dualex是一款源自于法国国家科学院 (CNRS)及巴黎第十一大学技术,由奥地利PESSL公司生产(原法国Force-A公司)开发的新型多功能叶片测量仪。它可同时准确测量叶片的叶绿素含量、叶片表层的类黄酮和花青素含量,适用于植物生理学和农学(如水稻叶绿素浓度,玉米氮素状况,葡萄藤等)相关研究。其测量对象可以是单子叶植物,双子叶植物或多年生植物。这款设备简单易用,可进a行实时和非破坏性测量。由于不需要校准标定和事先的样品制备,测量工作可在实验室或现场完成。此外,该设备在各种温度的和环境光照条件下均可正常使用。系统采用专利设计,光学传感器可进行简单、快速、无损测量叶片中的叶绿素、多酚以及花青素。
Dualex便携式智能气象-叶绿素-花青素-黄酮醇测量仪
相关阅读
Dualex 便携式智能气象-叶绿素-花青素-黄酮醇测量仪
PESSL便携式便携式植物多酚-叶绿素仪原理
Dualex植物多酚-叶绿素仪:腐殖酸通过铁依赖和非铁依赖的协同机制缓解禾本科植物的铁失绿症
Dualex植物多酚-叶绿素仪:硝化抑制剂和/或间作效应下玉米(和小麦灌溉种植系统中的硝酸盐淋失
Dualex植物多酚-叶绿素仪:与保持绿色表达相关的叶片和冠层性状与对水分胁迫具有不同耐性的小麦基因型的产量构成密切相关
Dualex植物多酚-叶绿素仪:基于地面和智能传感器的冬小麦营养营养仪
Dualex植物多酚-叶绿素仪:增加角质层蜡沉积不会改变残余叶片蒸腾作用Dualex植物多酚-叶绿素仪--氮平衡指数:不同生物刺激剂对水培生菜的效果比较
Dualex植物多酚-叶绿素仪:固体消化物和葡萄园冬季修剪堆肥替代苗圃中微繁殖高丛蓝莓生长基质中的泥炭研究
Dualex植物多酚-叶绿素仪:不同灌溉制度下根际细菌和藻类对金盏草生理生化指标的影响
Dualex植物多酚-叶绿素仪:Sentinel-2A与近端传感器数据协同提取水稻不同生育期生化参数
Dualex植物多酚-叶绿素仪:三种便携式光学传感器在冬小麦氮素状况无损诊断中的应用
Dualex植物多酚-叶绿素仪:基于微碳技术(MCT®)的肥料对土壤和辣椒生长室和田间培养的生物刺激效应
Dualex植物多酚-叶绿素仪:根际细菌在减轻大豆干旱胁迫中的作用
Dualex植物多酚-叶绿素仪:不同辐射组分下水分亏缺对苹果幼苗生长的影响
Dualex植物多酚-叶绿素仪:不同的非生物光谱途径揭示了不同物种的病原体应激信号
Dualex植物多酚-叶绿素仪:用于在田间估算葡萄叶片氮状况的反射指数和手持设备的性能
Dualex植物多酚-叶绿素仪:短期采前补充UV-B可提高罗勒叶片贮藏期间的多酚含量和抗氧化能力
Dualex植物多酚-叶绿素仪:基于图像处理技术的5种红树林叶片形态特征及叶绿素相对含量的估测
Dualex植物多酚-叶绿素仪:利用叶片荧光传感器估算玉米各生育期植株氮浓度Dualex植物多酚-叶绿素仪:便携式叶绿素仪测量作物叶片叶绿素浓度的评估Dualex植物多酚-叶绿素仪:从高光谱图像和SIF反演估算辐射传输Vcmax来评估雨养和灌溉植物表型试验中的光合性能
Dualex植物多酚-叶绿素仪:单金属和双金属植物纳米颗粒对Mezquit生理状态的影响
Dualex植物多酚-叶绿素仪:LED照明剂量对tatsoi光合指标的影响
Dualex植物多酚-叶绿素仪:利用Dualex非破坏性测量确定不同甜樱桃园的覆盖下光有效性™
Dualex植物多酚-叶绿素仪:硅在渗透胁迫下介导两种不同番茄基因型差异耐逆反应中的调节作用
Dualex植物多酚-叶绿素仪:用非破坏性荧光传感器监测两个苹果品种对供水条件的生理生化反应
Dualex植物多酚-叶绿素仪:从Sentinel-2光谱带反演冠层叶绿素含量以估算冬小麦集约种植系统的氮素吸收
Dualex植物多酚-叶绿素仪:胚胎大小作为种子捕食耐受性性状:胚胎受损种子对植株再生的贡献
来源:北京博普特科技有限公司
联系电话:010-82794912
E-mail:1206080536@qq.com
