当前位置 > 首页 > 技术文章 > 利用Dualex氮平衡指数仪估算冬小麦集约种植系统的氮素吸收
浏览次数:1252 发布日期:2022-5-7  来源:本站 仅供参考,谢绝转载,否则责任自负
热点
小麦含氮量只能用哨-21的10m波段
在冠层水平上准确估计了小麦氮含量。
像素内的异质性影响GAI估计精度。
红边带增加了生长季节的GAI估计精度。
摘要
在农业系统中,减少氮输入是最常见的调整环境氮输入的方法之一。这种调整通常与基于作物冠层(分别为NC和CNC)中临界和实际吸收氮(kg/ha)概念的氮营养指数(NNI)有关。因此,基于免费提供的卫星图像,在大面积范围内准确估计NC和CNC是需要解决的关键问题。本研究基于农民田地的大量数据集,强调了高度相关性(R2) = 用人工神经网络(ANN)从Sentinel-2(S2)反演的小麦CNC和冠层叶绿素含量(CCC)之间的差异为0.90)。估计值与4和21kg/ha(取决于生长阶段)的误差有关,这是评估NNI的一个有前景的结果。这个结果有四个主要结果:(i)在树冠水平上工作的重要性;(ii)与所考虑品种的关系的独立性;(iii)关系对成长阶段的依赖性;以及(iv)仅使用10个 M S2波段,为精准农业开辟道路。同时,研究了与CNC和NC相关的三个生物物理变量(BV)的估计精度,即绿地指数(GAI)、叶片叶绿素含量(Cab)和CCC。从这一分析中,对红边带的附加值进行了量化,以改进对3个感兴趣BV的估计,以及与现场异质性相关的性能降低。
关键词:氮含量,冠层叶绿素含量,人工神经网络,红边带,哨兵-2,缩放问题,集约种植制度
Retrieval of the canopy chlorophyll content from Sentinel-2 spectral bands to estimate nitrogen uptake in intensive winter wheat cropping systems
Highlights
The wheat nitrogen content can be estimated only with the 10 m bands of Sentinel-2.
The wheat nitrogen content is accurately estimated at the canopy level.
Within-pixel heterogeneity affects the GAI estimation accuracy.
The red-edge bands increase the GAI estimation accuracy along the growing season.
Abstract
One of the most common approaches to reducing the environmental impact of nitrogen (N) fertilisation in intensive agrosystems is to adjust the N input of the crop requirement. This adjustment is frequently related to the nitrogen nutrition index (NNI) based on the concepts of the critical and actual N absorbed (kg/ha) in the crop canopy (respectively, NC and CNC). Accurate estimation of the NC and CNC at the field scale over large areas based on freely available satellite imagery is thus a key issue to address. Relying on a large dataset of farmers' fields, this study highlights the high correlation (R2 = 0.90) between the wheat CNC and canopy chlorophyll content (CCC) retrieved from Sentinel-2 (S2) with an Artificial Neural Network (ANN). The estimation is related to errors of 4 and 21 kg/ha (depending on the growing stage), which is a promising result for evaluating the NNI. There are four major outcomes from this result: (i) the importance of working at the canopy level; (ii) the independence of the relationship to the considered cultivars; (iii) the dependence of the relationship on the growing stage; and (iv) the potential to use only the 10 m S2 bands, opening the way for precision agriculture. In parallel, estimation accuracies were investigated for the three biophysical variables (BV) related to the CNC and NC, i.e., the green area index (GAI), leaf chlorophyll content (Cab) and CCC. From this analysis, the added value of the red-edge bands for improving the estimation of the 3 BVs of interest was quantified as was the performance reduction related to the field heterogeneity.
Keywords
Nitrogen content
Canopy chlorophyll content
Artificial neural network
Red-edge bands
Sentinel-2
Scaling issue
Intensive cropping systems
Dualex是一款源自于法国国家科学院 (CNRS)及巴黎第十一大学技术,由奥地利PESSL公司生产(原法国Force-A公司)开发的新型多功能叶片测量仪。它可同时准确测量叶片的叶绿素含量、叶片表层的类黄酮和花青素含量,适用于植物生理学和农学(如水稻叶绿素浓度,玉米氮素状况,葡萄藤等)相关研究。其测量对象可以是单子叶植物,双子叶植物或多年生植物。这款设备简单易用,可进a行实时和非破坏性测量。由于不需要校准标定和事先的样品制备,测量工作可在实验室或现场完成。此外,该设备在各种温度的和环境光照条件下均可正常使用。系统采用专利设计,光学传感器可进行简单、快速、无损测量叶片中的叶绿素、多酚以及花青素。
相关阅读
Dualex 便携式智能气象-叶绿素-花青素-黄酮醇测量仪
PESSL便携式便携式植物多酚-叶绿素仪原理
Dualex植物多酚-叶绿素仪:腐殖酸通过铁依赖和非铁依赖的协同机制缓解禾本科植物的铁失绿症
Dualex植物多酚-叶绿素仪:硝化抑制剂和/或间作效应下玉米(和小麦灌溉种植系统中的硝酸盐淋失
Dualex植物多酚-叶绿素仪:与保持绿色表达相关的叶片和冠层性状与对水分胁迫具有不同耐性的小麦基因型的产量构成密切相关
Dualex植物多酚-叶绿素仪:基于地面和智能传感器的冬小麦营养营养仪
Dualex植物多酚-叶绿素仪:增加角质层蜡沉积不会改变残余叶片蒸腾作用
Dualex植物多酚-叶绿素仪--氮平衡指数:不同生物刺激剂对水培生菜的效果比较
Dualex植物多酚-叶绿素仪:固体消化物和葡萄园冬季修剪堆肥替代苗圃中微繁殖高丛蓝莓生长基质中的泥炭研究
Dualex植物多酚-叶绿素仪:不同灌溉制度下根际细菌和藻类对金盏草生理生化指标的影响
Dualex植物多酚-叶绿素仪:Sentinel-2A与近端传感器数据协同提取水稻不同生育期生化参数
Dualex植物多酚-叶绿素仪:三种便携式光学传感器在冬小麦氮素状况无损诊断中的应用
Dualex植物多酚-叶绿素仪:基于微碳技术(MCT®)的肥料对土壤和辣椒生长室和田间培养的生物刺激效应
Dualex植物多酚-叶绿素仪:根际细菌在减轻大豆干旱胁迫中的作用
Dualex植物多酚-叶绿素仪:不同辐射组分下水分亏缺对苹果幼苗生长的影响
Dualex植物多酚-叶绿素仪:不同的非生物光谱途径揭示了不同物种的病原体应激信号
Dualex植物多酚-叶绿素仪:用于在田间估算葡萄叶片氮状况的反射指数和手持设备的性能
Dualex植物多酚-叶绿素仪:短期采前补充UV-B可提高罗勒叶片贮藏期间的多酚含量和抗氧化能力
Dualex植物多酚-叶绿素仪:基于图像处理技术的5种红树林叶片形态特征及叶绿素相对含量的估测
Dualex植物多酚-叶绿素仪:利用叶片荧光传感器估算玉米各生育期植株氮浓度
Dualex植物多酚-叶绿素仪:便携式叶绿素仪测量作物叶片叶绿素浓度的评估
Dualex植物多酚-叶绿素仪:从高光谱图像和SIF反演估算辐射传输Vcmax来评估雨养和灌溉植物表型试验中的光合性能
Dualex植物多酚-叶绿素仪:单金属和双金属植物纳米颗粒对Mezquit生理状态的影响
Dualex植物多酚-叶绿素仪:LED照明剂量对tatsoi光合指标的影响
Dualex植物多酚-叶绿素仪:利用Dualex非破坏性测量确定不同甜樱桃园的覆盖下光有效性™
Dualex植物多酚-叶绿素仪:硅在渗透胁迫下介导两种不同番茄基因型差异耐逆反应中的调节作用
来源:北京博普特科技有限公司
联系电话:010-82794912
E-mail:1206080536@qq.com
