当前位置 > 首页 > 技术文章 > 利用叶绿素仪非破坏性测量确定不同甜樱桃园的覆盖下光有效性
浏览次数:1971 发布日期:2022-5-7  来源:本站 仅供参考,谢绝转载,否则责任自负
热点
甜樱桃树为纺锤形或树篱。
在覆盖物下以不同的间隔种植,用于早熟作物或开阔地。
每公顷产量最大的灌木篱笆树。
树篱覆盖下用Dualex测量的FLAV指数小幅下降™.
树篱覆盖下截获光的小幅度减少。
摘要
气候条件的变化使得有必要制定樱桃栽培保护策略。本研究的目的是使用Dualex研究不同覆盖种植系统中与光可用性相关的生理过程™ 用于非破坏性测量。因此,樱桃树要么被训练成树篱,即最密集的种植([2.35米*2]*1.5米),要么被训练成纺锤状(2.70米*2.0米;1.75米*2.9米),在德国波恩附近的克莱恩·阿尔滕多夫种植,或在开阔的田野中种植。不同植株的叶面积没有差异。使用Dualex进行无创测量™ 表明,由于光照不足,作物覆盖下的绿篱树的相对叶片叶绿素含量(Chl=30-33)高于叶绿素含量较低(ChI=26-28)的开阔地生长的叶片。同样,类黄酮指数(Flav)作为表皮类黄酮和光照条件的相对测量值,在作物覆盖下通常较低,在近轴叶侧的绿篱树中最低,与开阔地中的1.6-1.8相比,Flav=1.4-1.5,但始终保持这些值高于1-1.2的临界光照水平。非侵入性测量显示,覆盖下的茂密树篱树冠层内的光照减少高达80%,符合Flav和ChI的最低值。虽然在最佳光照条件(1.75 m*2.9 m)的种植系统中,每棵树的产量最高,但在最密集的种植(2.7 m*2.0 m)中,每英亩的产量最高,有树篱覆盖,这是高产和水果品质与良好光照可用性的理想结合。总体而言,我们的结果表明,光有效性取决于树冠结构、种植系统和树木密度。Flav和ChI指数为评估果园的光照条件提供了可能性,并为优化种植系统提供了参考。
关键词:甜樱桃(Prunus avium L.)、非生物胁迫、叶绿素荧光、气候变化、光限制、设施栽培
Identification of light availability in different sweet cherry orchards under cover by using non-destructive measurements with a Dualex™
Highlights
Sweet cherry trees trained as spindle or hedgerow on dwarfing rootstock.
Planted at different spacing under cover for early crop or open field.
Hedgerow trees under cover with largest yield per ha.
Hedgerow under cover small reduction in FLAV index measured with a Dualex™.
Hedgerow under cover small reduction in intercepted light (Sunscan).
Abstract
Changing climatic conditions makes the development of cultivation strategies for protected cherry cultivation necessary. The objective of the present study was to investigate physiological processes in connection with light availability in different planting systems under cover using a Dualex™ for non-destructive measurements. Hence, cherry trees were either trained as hedgerows, i.e. the most dense planting ([2.35 m*2]*1.5 m), or trained as spindles (2.70 m*2.0 m; 1.75 m*2.9 m) and grown under cover or in the open field at Klein-Altendorf near Bonn, Germany. There was no difference in leaf area between the plantings. Non-invasive measurements with the Dualex™ (Force A, France) showed that a larger relative leaf chlorophyll content (Chl = 30–33) in the hedgerow trees under crop cover as a result of less light than in the open field-grown leaves with less chlorophyll (ChI = 26–28). Similarly, the flavonoid index (Flav), as a relative measure of the epidermal flavonoids and light condition, was generally lower under crop cover and lowest in the hedgerow trees on the adaxial leaf side with Flav = 1.4–1.5 relative to 1.6–1.8 in the open field, but always maintained these high values above the critical light level of 1–1.2. Non-invasive SunScan measurements showed light reductions of up to 80% inside the canopy of the dense hedgerow trees under cover in line with the lowest values for Flav and ChI. Although the largest yield per tree was obtained in the planting system with the best light conditions (1.75 m*2.9 m), the largest yield per acreage was found in the most dense planting (2.7 m*2.0 m) with hedgerows under cover as an ideal combination of a high yield and fruit quality with good light availability. Overall, our results showed that light availability depends on crown structure, planting system and tree density. The indices Flav and ChI offer the possibility to evaluate the light conditions in an orchard easily and to give a recommendation for an optimized growing system.
Keywords:Sweet cherry (Prunus avium L.),Abiotic stress,Chlorophyll fluorescence,Climate change,Light limitation,Protected cultivation
Dualex是一款源自于法国国家科学院 (CNRS)及巴黎第十一大学技术,由奥地利PESSL公司生产(原法国Force-A公司)开发的新型多功能叶片测量仪。它可同时准确测量叶片的叶绿素含量、叶片表层的类黄酮和花青素含量,适用于植物生理学和农学(如水稻叶绿素浓度,玉米氮素状况,葡萄藤等)相关研究。其测量对象可以是单子叶植物,双子叶植物或多年生植物。这款设备简单易用,可进a行实时和非破坏性测量。由于不需要校准标定和事先的样品制备,测量工作可在实验室或现场完成。此外,该设备在各种温度的和环境光照条件下均可正常使用。系统采用专利设计,光学传感器可进行简单、快速、无损测量叶片中的叶绿素、多酚以及花青素。
Dualex便携式智能气象-叶绿素-花青素-黄酮醇测量仪
相关阅读
Dualex 便携式智能气象-叶绿素-花青素-黄酮醇测量仪
PESSL便携式便携式植物多酚-叶绿素仪原理
Dualex植物多酚-叶绿素仪:腐殖酸通过铁依赖和非铁依赖的协同机制缓解禾本科植物的铁失绿症
Dualex植物多酚-叶绿素仪:硝化抑制剂和/或间作效应下玉米(和小麦灌溉种植系统中的硝酸盐淋失
Dualex植物多酚-叶绿素仪:与保持绿色表达相关的叶片和冠层性状与对水分胁迫具有不同耐性的小麦基因型的产量构成密切相关
Dualex植物多酚-叶绿素仪:基于地面和智能传感器的冬小麦营养营养仪
Dualex植物多酚-叶绿素仪:增加角质层蜡沉积不会改变残余叶片蒸腾作用
Dualex植物多酚-叶绿素仪--氮平衡指数:不同生物刺激剂对水培生菜的效果比较
Dualex植物多酚-叶绿素仪:固体消化物和葡萄园冬季修剪堆肥替代苗圃中微繁殖高丛蓝莓生长基质中的泥炭研究
Dualex植物多酚-叶绿素仪:不同灌溉制度下根际细菌和藻类对金盏草生理生化指标的影响
Dualex植物多酚-叶绿素仪:Sentinel-2A与近端传感器数据协同提取水稻不同生育期生化参数
Dualex植物多酚-叶绿素仪:三种便携式光学传感器在冬小麦氮素状况无损诊断中的应用
Dualex植物多酚-叶绿素仪:基于微碳技术(MCT®)的肥料对土壤和辣椒生长室和田间培养的生物刺激效应
Dualex植物多酚-叶绿素仪:根际细菌在减轻大豆干旱胁迫中的作用
Dualex植物多酚-叶绿素仪:不同辐射组分下水分亏缺对苹果幼苗生长的影响
Dualex植物多酚-叶绿素仪:不同的非生物光谱途径揭示了不同物种的病原体应激信号
Dualex植物多酚-叶绿素仪:用于在田间估算葡萄叶片氮状况的反射指数和手持设备的性能
Dualex植物多酚-叶绿素仪:短期采前补充UV-B可提高罗勒叶片贮藏期间的多酚含量和抗氧化能力
Dualex植物多酚-叶绿素仪:基于图像处理技术的5种红树林叶片形态特征及叶绿素相对含量的估测
Dualex植物多酚-叶绿素仪:利用叶片荧光传感器估算玉米各生育期植株氮浓度
Dualex植物多酚-叶绿素仪:便携式叶绿素仪测量作物叶片叶绿素浓度的评估
Dualex植物多酚-叶绿素仪:从高光谱图像和SIF反演估算辐射传输Vcmax来评估雨养和灌溉植物表型试验中的光合性能
Dualex植物多酚-叶绿素仪:单金属和双金属植物纳米颗粒对Mezquit生理状态的影响
Dualex植物多酚-叶绿素仪:卫星和近端传感技术用于评估食用葡萄的产量和质量
来源:北京博普特科技有限公司
联系电话:010-82794912
E-mail:1206080536@qq.com
