当前位置 > 首页 > 技术文章 > 同时测定小麦原生质体的电流与离子流,发现电流与K+密切相关,与Ca2+无关
浏览次数:8280 发布日期:2009-5-12  来源:本站 仅供参考,谢绝转载,否则责任自负
 K+、Ca2+流与电流的关系(非损伤微电极与膜片钳的结合)
钾是植物生长发育必不可少的元素,离子的流向决定了钾营养循环利用的效率。目前,承担离子转运的许多分子已被分离和鉴定,但运输方向的调控机制目前尚不清楚。
剑桥大学的Matthew Gilliham等研究人员在《The Plant Journal》发表研究论文,应用膜片钳技术获得小麦根原生质体的全细胞外形及电流-电压关系,并通过"非损伤微测技术"检测出质膜K+和Ca2+净离子流速,与通过膜片钳技术测得的电流强度做比较后发现,K+流速/强度的比值变化反映了质膜上KORC通道的不同分布,而且Ca2+流速与K+通道的激活并没有相关性。
研究表明当检测到较强的Ca2+流时并未产生电流,也就是使用膜片钳技术研究Ca2+通道时,即使没有检测到电流,但很可能存在Ca2+流。所以,同时检测跨膜的离子流和电流才能准确地确定离子载体和离子通道的数量和类别。
点击查看大图
上图:KORC电流与K+流速密切相关,与Ca2+无关
关键词:微电极离子流测定 ( Microelectrode Ion-Flux Estimation); 膜片钳(Patch clamp)
参考文献:Matthew G. et al. The Plant Journal. 2006, 46:134-144
全文下载:http://www3.interscience.wiley.com/cgi-bin/fulltext/118565019/HTMLSTART
Simultaneous flux and current measurement from single plant protoplasts reveals a strong link between K+ fluxes and current, but no link between Ca2+ fluxes and current
Matthew Gilliham 1,2*, Wendy Sullivan 2 , Mark Tester 3,4 and Stephen D. Tyerman 2
  1 Department of Plant Sciences, University of Cambridge, Downing Street, Cambridge, CB2 3EA, UK,
  2 School of Agriculture and Wine, Plant Research Centre, University of Adelaide, Waite Campus, PMB 1, Glen Osmond, SA 5064, Australia,
  3 Australian Centre for Plant Functional Genomics, PMB 1, Glen Osmond, SA 5064, Australia, and
  4 School of Agriculture and Wine, University of Adelaide, Australia
Correspondence to   *(fax +44 (0)1223 333953; e-mail mg253@cantab.net).
Copyright 2006 The Authors Journal compilation 2006 Blackwell Publishing Ltd
KEYWORDS
non-invasive self-referencing microelectrode ion-flux measurement • ion-selective electrodes • Microelectrode Ion-Flux Estimation • patch clamp electrophysiology • ion channels • selectivity
ABSTRACT
We present a thorough calibration and verification of a combined non-invasive self-referencing microelectrode-based ion-flux measurement and whole-cell patch clamp system as a novel and powerful tool for the study of ion transport. The system is shown to be capable of revealing the movement of multiple ions across the plasma membrane of a single protoplast at multiple voltages and in complex physiologically relevant solutions. Wheat root protoplasts are patch clamped in the whole-cell configuration and current–voltage relations obtained whilst monitoring net K+ and Ca2+ flux adjacent to the membrane with ion-selective electrodes. At each voltage, net ion flux (nmol m−2 sec−1) is converted to an equivalent current density (mA m−2) taking into account geometry and electrode efficiency, and compared with the net current density measured with the patch clamp system. Using this technique, it is demonstrated that the K+-permeable outwardly rectifying conductance (KORC) is responsible for net outward K+ movement across the plasma membrane [1:1 flux-to-current ratio (1.21 ± 0.14 SEM, n = 15)]. Variation in the K+ flux-to-current ratio among single protoplasts suggests a heterogeneous distribution of KORC channels on the membrane surface. As a demonstration of the power of the technique we show that despite a significant Ca2+ permeability being associated with KORC (analysis of tail current reversal potentials), there is no correlation between Ca2+ flux and KORC activity. A very significant observation is that large Ca2+ fluxes are electrically silent and probably tightly coupled to compensatory charge movements. This analysis demonstrates that it is mandatory to measure flux and currents simultaneously to investigate properly Ca2+ transport mechanisms and selectivity of ion channels in general.
来源:旭月(北京)科技有限公司
联系电话:010-82622628;010-62656315;010-62523549
E-mail:china@youngerusa.cn
