集冷藏/孵育/旋转/振荡/搅拌/五项功能于一体的多功能恒温孵育箱
浏览次数:6777 发布日期:2001-1-20
来源:本站 本站原创,转载请注明出处
NEW! Enviro-Genie 多功能恒温孵育箱
"Environmentally Controlled Benchtop
可设定温度4℃至75℃的恒温范围
使用最新电热原理 (Peltier)
不须压缩机而达到制冷和加热
精确的微电脑控制全操作,液晶显示操作过程,长达96小时的程控程序,并有可发出报警讯号
包括2个1-2000 RPM''''s磁力搅拌器
优异的性价比和节省工作空间
The Enviro-Genietm is a unique benchtop refrigerated/incu
incubator which includes an all-in-one rotator/rocker and 2 magnetic stirrers for the study of micro-organisms and tissue cell growth under strictly controlled conditions of temperature and agitation. Designed to provide the precise temperature control and uniformity required for demanding incubation/refrigeration applications without taking up a great deal of space. The unit is equipped with two revolutionary magnetic stirrers featuring a speed range of 1-2000 RPM and include stir reverse. Chamber air is gently and continuously circulating at a rate that ensures the temperature consistency and uniformity of all test samples. Shatter resistant viewing windows allow for inspection of samples without affecting the chamber environment.
Microprocessor controls easily achieve desired rotating, rocking and stirring speed, temperature, and time; displayed on large LEDs for accurate reproducible conditions. Timer displays elapsed time or remaining time until programmed off up to 96 hours. Visible and audible alarms for temperature and time.
性能参数 :
温度控制 :
范围: 4oC - 75oC
精确度: +/- 0.2oC
一致性: +/- 0.5oC
精密度: 0.1oC
稳定度: +/- 0.1oC
时 间 :
96小时程控控制
警 报 :
时间和温度警报
容 量 :
适用于大多数实验室试管和小瓶,大口烧杯,培养瓶,组织培养及各种盘子等(Erlenmeyer , and microtiter plates, membrane blots, plastic bags and staining trays)
旋 转 :
使用数字控制/ 显示 :
1 - 35 RPM
振 荡 :
使用数字控制/ 显示 :
2 – 70 RPM
搅 拌 :
数字控制磁力搅拌器和液晶显示: 1 - 2000 RPM
规 格 :
Supplied with
a two-sided magnetic platform, 1 clip plate of each size tubes (10-13mm, 15-17mm and 28-30mm)
4 magnetic stainless steel mounting strips, 1 non-skid metal rocker tray (8"x12"),
2 magnetic stirrers, and 1 wire rack
Chamber dimensions (cm)
10"x14-1/4"x10-1/4" (25.4x36.2x26.0)
Overall dimensions
19-1/2"x24-1/2"x14-1/2" (49.5x62.2x36.8)
Weight (kg)
80 lbs. (36)
Chamber volume (L)
.86 cu feet (24)
Warranty
2-year manufacturer warranty
Workload capacity (kg)
10 lbs. (4.5)
泽泉科技有限公司提供
Zeal Quest Scientific Technology Co.,Ltd
地址: 上海市华山路1038弄173号306座 邮编: 200050
电话: 021-62409434 传真: 021-62400735
Email: zealquest@cm163.net
2001年1月20日
